Page 2 of 3 1 2 3
Re: mounting blitz gas can? [Re: Inyo_man] #1011287 10/20/10 03:05 PM
icysyrup Offline
I would put it on the spare. In those pics you loose what limited rear visibility thats already there. The way you are talking about it should work....shouldnt have to get crazy thick on it imo.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: mounting blitz gas can? [Re: icysyrup] #1011288 10/20/10 10:59 PM
Inyo_man Offline OP
Thanks to all for your input.
Most likely I'll be collecting all of the parts over the next month or so, and fabricating some time in Dec.
I would be on it sooner, but I've got two back-country trips lined up for Nov.
I'll post some pics. once it's underway.
'02 Montero: OME suspension, ARB front bumper, homemade skid plates & spare tire Blitz can mount, extended diff. breather, K&N air filter, Optima Yellow Top, BajaRack, IPF lights, Goodyear Duratrac 265/75/16's, RUD 4x4 Grip chains
Re: mounting blitz gas can? [Re: Inyo_man] #1011289 10/21/10 04:25 AM
dougl3nc Offline
If you decide to make an extra, I'd be interested in buying one.
I happen to have a 50's era German jerry can (the real wehrmacht can) that I'm refinishing...it really wants to ride on the monty.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: mounting blitz gas can? [Re: dougl3nc] #1011290 10/21/10 02:12 PM
You can fund used confer can holders like Les'. I found a used one for sale online. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: mounting blitz gas can? [Re: off-roader] #1011291 10/22/10 05:02 AM
Or you can use the Blitz mount by bolting/welding it to the back door. Drill a little hole for key-lock access and MIG some vertical supports for strength.
[Linked Image] First I MIGed the holes then drilled and bolted them.
[Linked Image] Cutting the 3/4" X 3/4" square tube.
[Linked Image] Supports MIGed.
[Linked Image] Primed and plastic piece notched out.
The added supports are crucial because the Blitz can holder alone is kind of flimsy. I also added a bike cable lock that goes through the handle and between the mount and rear door.
Re: mounting blitz gas can? [Re: off-roader] #1011292 10/22/10 08:08 AM
4x4Wire Offline
Personally, I am not a fan of the Confer mounts. Nor do I like the look of the Blitz holders.
The weak point is the clamp to the can at the handle point. I have lost a couple of cans where the handle weld has broken.
I don't have a problem with the bottom portion where the ridge is held in the clamp. The failure point is where the upper part clamps to the can handle.
My solution has been to run a Velcro strap around the can and mount to keep vibration stresses to a minimum.
Whether the Blitz or Confer mount, the issue is to secure the can in place. That is where the Velcro strap is necessary.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: mounting blitz gas can? [Re: icysyrup] #1011293 10/22/10 08:26 AM
Bernoulli Offline
Gasoline is probably the most dangerous common substance we all come in regular contact with. It sure makes me nervous to see these solutions. I pull a 4X8 utility trailer with a custom made 50 gallon tank mounted over the axle of the trailer - in the U.S.
Over here in OZ, there are long range tanks made for some of the Pajero models. They are expensive and I imagine the shipping to the U.S. would be prohibitive. In most areas here, fuel tanks mounted externally are illegal. Diesels have better range, of course, but that doesn't help you.
I used to figure 100 miles in 4WD on my 2.6L Monteros. Finally finding a V6 Raider helped a lot with better mileage an a larger tank. I don't have a good answer, but I repeat; those solutions sure make me nervous.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: mounting blitz gas can? [Re: 4x4Wire] #1011294 10/22/10 08:27 AM
mxmikie Offline
got any pictures of this ????
Re: mounting blitz gas can? [Re: mxmikie] #1011295 10/22/10 08:48 AM
4x4Wire Offline
No because I came across this issue about 15 years ago and have since changed my gas can mounting strategy.
Basically, the Confer mount depends on the can riding on a groove on the bottom of the mount with a clamp over the top handle of the can. I still have one mounted on my Jeep but do have a Velcro strap that I run around the can and behind the mount to provide a safety support and take the vibration strain off the upper clamp.
With the Blitz holder, I have found that the metal is weak and need a support under the bottom. A picture posted provides proof of that weakness. And, there is no real supportive framework to keep vibrations down and the can in a secure position.
My optimum solution is for a can mount that is integrated with the tire carrier. And, the can mount has a solid base with a "cage" that allows the can to be strapped into position and weight is carried by the base support and a stabilizing strap coming from a solid point down across the can to its mounting base.
Check http://www.wildernessracks.com/ for ideas. Personally, I am a fan of Garvin Wilderness Racks.
John Stewart
Editor - 4x4Voice
Re: mounting blitz gas can? [Re: 4x4Wire] #1011296 10/22/10 05:07 PM
I can see what you mean John. Fortunately in my case, an 'empty' can will be there more as a tail gater 'buffer' LOL. My Nato cans (4) are mounted on the roof using a purpose built gas can mount.
Reminds me though that I need to modify the mount that came with mine so I can put it on.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6445 MB (Peak: 0.7561 MB) Data Comp: Off Server Time: 2026-06-20 18:43:03 UTC
