Re: Trail Gear Rock Sliders [Re: jdavis] #1011387 10/21/10 11:28 PM
Montypower - Interesting, no plans for a body lift. I thought the SRs came from the factory with a two inch body lift, can anyone confirm that. If it doesn't, then you are right, I should look into that before adding the sliders.
I've heard it said that SR's come with a 1" lift, not 2" although I'd like to compare an SR with an LS from the same year Montero to know for sure. Not just checking the distance from the body mount but the distance from the body to the actual frame on both vehicles.
Re: Trail Gear Rock Sliders [Re: off-roader] #1011388 10/22/10 12:35 AM
zarktheshark Offline
The rig is not in wheeling condition right now. I have everything stripped off of it getting it ready for paint. But one of these days I'll be up there in the trails.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Trail Gear Rock Sliders [Re: jdavis] #1011389 10/22/10 04:13 AM
Thanks for the responses!
Anyone know how to do multiple quotes?
Sure do. You have to use the 'open quote'/'closed quote' syntax for the 1st Section your quoting then put your comments, then use the 'open quote'/'closed quote' syntax for the 2nd quoted section, then your comments, and so on for each quoted section. If you do it right it will look like this post.
Off-Roader: I hear you, no problem with constructive criticism
Don't worry, I wasn't referring to you when I said that. There's a story behind the thread I linked to that you didn't know about but others got to 'experience' <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Trail Gear Rock Sliders [Re: off-roader] #1011390 10/23/10 04:09 AM
sparkem Offline
Yeah, no bugger welds.
I believe the 95SR has the body mounts welded 1 inch higher. Not a body lift spacer between the body and mounts.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6105 MB (Peak: 0.6671 MB) Data Comp: Off Server Time: 2026-06-21 18:52:43 UTC
