skid plates #1011449 10/22/10 04:23 AM
Red1979 Offline OP
Is there anyone out there that makes skid plates for my 87 ram 50. I am looking for one for the gas tank and a better one for my oil pan
1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
Re: skid plates [Re: Red1979] #1011450 10/22/10 05:54 PM
Nope. <img src="/forums/images/graemlins/frown.gif" alt="" /> Reinforce yours or if they're already trashed, find a good set in a pick n pull and reinforce them to your needs. Don't forget to also reinforce the mount points on the frame. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: skid plates [Re: Red1979] #1011451 10/22/10 06:33 PM
The 4wd trucks had them but may not be a direct fit. The gen1 truck had a different frame than the 2wd, iirc.
Re: skid plates [Re: fasteddy] #1011452 10/22/10 08:33 PM
I think his is a 4wd truck cause in his sig he mentions the front's are locked/welded.
Re: skid plates [Re: off-roader] #1011453 10/22/10 10:46 PM
Red1979 Offline OP
Yeah I got an 87 pickup. It has the front plate but doesn't cover the oil pan. It doesn't have anything to cover the gas tank. I moved the gas tank up about 4 inches....I don't think I would have trouble with the one to cover the oil pan but the gas tank would be tricky
1987 Dodge Ram 50
2.6 5 speed
Re: skid plates [Re: Red1979] #1011454 10/22/10 11:15 PM
My 85 4wd d50 needed a tank skid plate. Lots of banging going on with that long overhang "long bed". I always wanted to flatbed that truck and relocate a custom tank ahead of the rear axle, maybe up to the bottom of the flatbed which would be at top of frame arch at the rear axle. The pickup has a really good approach angle stock, and with a bobbed rear end, to no more than a foot behind the rear wheel, it ought to slop around really well.
PHP: 7.4.33 Page Time: 2.111s Queries: 15 (0.003s) Memory: 0.6118 MB (Peak: 0.6823 MB) Data Comp: Off Server Time: 2026-06-23 03:56:30 UTC
