Re: Idle Air Control Valve does not seem to be the problem need some advice. [Re: hazy_daze] #1011497 10/23/10 05:18 PM
mxmikie Offline
vac leak at the intake butterfly shaft i have one that is plugged and ready to bolt on
Re: Idle Air Control Valve does not seem to be the problem need some advice. [Re: mxmikie] #1011498 10/23/10 06:52 PM
leftnutt35 Offline OP
Hazy Day thanks. doing the pcv does not sound to bad. but i can't do it right now my Psoriasis arthritis is really bad right now so no go for now. Any one close to me smile
95 SR stock but i hope not for long....
Re: Idle Air Control Valve does not seem to be the problem need some advice. [Re: leftnutt35] #1011499 10/23/10 10:05 PM
ok as i was thinking today and reading on the fourm . it dawned on me i did a no no.. i forgot to unhook the battery when changing the idle control valve. I am guessing that might be a no no. And should i do it now ? will it clear and reset things..
Re: Idle Air Control Valve does not seem to be the problem need some advice. [Re: leftnutt35] #1011500 10/24/10 12:32 AM
As long as the ignition was off, there should be no problem, but you are right, you should disco the battery - just to be safe. ISC's will fry the ecu with power to them and an internal short, sometimes, according to the anecdotal accounts I've heard.
Re: Idle Air Control Valve does not seem to be the problem need some advice. [Re: fasteddy] #1011501 10/24/10 02:58 AM
could be a throttle position sensor ?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6766 MB) Data Comp: Off Server Time: 2026-06-09 21:48:18 UTC
