For the record - Gen2 rear shocks compression/extension #1011631 10/25/10 06:50 AM
bretwalda Offline OP
Couldn't find the old thread that had this all figured out...Measured from bottom bolt center to the top mount plate
Max extension - 48.5cm (sway bar removed)
Max compression - 39.5cm (maybe 2-3cm's more, I'm checking it with OME medium duty springs in there and that's as far as it went before lifting the frame)
concreteprinter.com
Re: For the record - Gen2 rear shocks compression/extension [Re: bretwalda] #1011632 10/25/10 07:11 AM
While I'm at it - anyone have a link for KYB specifications - compression/extension specs specifically? They don't seem to have any <img src="/forums/images/graemlins/confused.gif" alt="" />
and oh - the Rancho 9000's are a joke. Might be nice for a pickup or some light end app but they don't do anything in my setup. I'm going with the Monomax's like I have up front. <img src="/forums/images/graemlins/kewl.gif" alt="" />
concreteprinter.com
Re: For the record - Gen2 rear shocks compression/extension [Re: bretwalda] #1011633 10/25/10 02:12 PM
Call KYB's support line if you can't find it. They're really good about helping with tech questions. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: For the record - Gen2 rear shocks compression/extension [Re: bretwalda] #1011634 10/25/10 09:53 PM
motero Offline
I just put some monomax shocks on the rear of mine, The ride is stiffer and the control is great. The gas adjusts I took of had 30k on them they were not up to high speed dirt driving any more. As far as length goes <img src="/forums/images/graemlins/confused.gif" alt="" />
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: For the record - Gen2 rear shocks compression/extension [Re: motero] #1011635 10/27/10 12:02 AM
Called KYB - the issue he said is that the OEM shock is "quite stiff" for the Gen2. KYB 'charges' their monotube shocks to be stiffer than OEM specs by a factor of 10-20%.
Any alternative would be a loss in stiffness compared to the OEM - he said any other shock would be around a 30% loss.
So you're stuck with their OEM replacement size. They measure from the thread shoulder to the eyelet center - so taking the polyurethane bushing and washer into consideration - that's about a loss of an inch compared to my previous measurements.
So - Monomax OEM replacement specs:
Monomax Extension max -18"
My measurement - 19.1" minus 1" for bushing - 18"
Monomax compression max - 11"
My measurement - 15.6"
So we're good.
...But then he gave me a part# which turned out to be the Gas Adjusts.
<img src="/forums/images/graemlins/lol.gif" alt="" /> - So I'll have to call them back and see what still applies. <img src="/forums/images/graemlins/kewl.gif" alt="" />
concreteprinter.com
Re: For the record - Gen2 rear shocks compression/extension [Re: bretwalda] #1011636 10/27/10 07:19 AM
xFezx Offline
Your profile pic is freaky. I've heard the KYB's are the way to go and not bad on price either. And I heard the ones that ship compressed shouldn't and the ones that need be aren't. So maybe you can mention that if you haven't called already.
You can call me Fez
'95 SR 15x8 steel rims w/ 33x12.5 Duratracs, cranked torsion bars, "Baja" lights
'09 Nissan Sentra SR
Re: For the record - Gen2 rear shocks compression/extension [Re: xFezx] #1011637 10/27/10 12:08 PM
Mad_Scientist Offline
Good work Phil <img src="/forums/images/graemlins/kewl.gif" alt="" /> My Gas Adjusts have about 80k on them so it's time for a new set. Monomax shocks look like the best choice, especially for flex in the rear
Re: For the record - Gen2 rear shocks compression/extension [Re: Mad_Scientist] #1011638 10/27/10 02:06 PM
hazy_daze Offline
*cough* Bilsteins *cough*
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: For the record - Gen2 rear shocks compression/extension [Re: hazy_daze] #1011639 10/27/10 06:10 PM
The Bilsteins look good - and the offroad versions are made with a lift in mind...but double the $$$.
I'll have to think on that.
Here's a list of the Mitsu Bilsteins - Off Road Warehouse
concreteprinter.com
Re: For the record - Gen2 rear shocks compression/extension [Re: bretwalda] #1011640 10/27/10 06:52 PM
Found a good thread with specs and Part#s - Outerlimits thread
concreteprinter.com
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.004s) Memory: 0.6329 MB (Peak: 0.7419 MB) Data Comp: Off Server Time: 2026-06-22 15:11:19 UTC
