Re: HG replacement - started the tear-down [Re: outdoorfan] #1011923 11/01/10 02:23 PM
toyrunner Offline
Well, this is going slower than I had planned due to other things coming up. I will start reassembly tomorrow. I got everything cleaned today. The old HG didn't look terrible; no obvious rips, tears, or blow-outs. Of course, it did fail, so I'm not saying it was perfect. The block looked good, thankfully. Sorry, no pictures.
I took the cooling fan clutch apart, and it was definitely low on silicone oil. So, I put some STP oil treatment in there. Believe it or not, the local Toyota parts guy suggested that since he said there was no other silicone oil readily available anywhere in the country. Anyway, I hope I didn't overdo it 'cause I filled it pretty full.
RC car differential silicone oil from any Hobby Shop.
I used the 10,000. It works well and that fan is going strong after two years. About $6.00 a bottle
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: HG replacement - started the tear-down [Re: kewlynx] #1011924 11/01/10 03:01 PM
O
outdoorfan Offline OP
Egged out- shape of gasket out of round; looks kind of like an egg-distorted.
Yep oil filter if coolant got in there. Glad the block is okay.
Yep, that's exactly what I saw on the back side of cylinder #4. The holes in the gasket for the water jackets weren't exactly lining up with the water jackets in the block.
Re: HG replacement - started the tear-down [Re: toyrunner] #1011925 11/01/10 03:02 PM
O
Thanks for the tip.
Re: HG replacement - started the tear-down [Re: outdoorfan] #1011926 11/03/10 12:52 AM
engnbldr Offline
>>>*Remember that many of the holes in the top of a block are there to ease removal of material in there from the casting process, similar to the lower block plugs, same reason is why they are there.
The gasket is designed and intended to restrict in some areas, this forces flow to more evenly distribute.
If it does not, then a difference in temperature (or thermals if you will) can happen, that difference in temperature then can cause expansion variations more in one area than another, causing a failure....*EB
*Beats the he** outa me!....*LOL**...
Re: HG replacement - started the tear-down [Re: engnbldr] #1011927 11/03/10 02:12 PM
O
Thanks for the explanation, EB.
I have it buttoned up now, and it seems to be running just fine. I haven't done a compression test yet just to verify, though.
When I fired it up I couldn't get the idle down below 2K. After much fussing around I realized that the throttle plate wasn't closing all the way. <img src="/forums/images/graemlins/scared.gif" alt="" />
As an aside, I've now snapped off 5 of the valve lash adjusting screws. I guess my version of "good and snug" was too much. Now I'm just making them "very slightly snug". <img src="/forums/images/graemlins/shiner.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6998 MB) Data Comp: Off Server Time: 2026-05-29 23:48:21 UTC
