Low beam not working #1012308 11/05/10 02:41 AM
G
Greg_Canada Offline OP
Hey guys... just put my lights back in, for a few minutes the driver side headlamp worked fine, now only the high beam works. I switched with new bulbs and still the same thing... only highbeam. Passenger side works fine. What could cause this?
89 4Runner
Re: Low beam not working [Re: Greg_Canada] #1012309 11/05/10 05:18 AM
4Crawler Offline
Try checking the voltage at the back of the connector and see what it tells you:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#VoltageTest
You could check the battery-common voltage and the low-ground voltage and if either reads significant, then that is the bad connection.
Re: Low beam not working [Re: 4Crawler] #1012310 11/05/10 06:48 PM
G
I checked the voltages they look good.
I was having a problem finding a good ground when in low beam however....?
89 4Runner
Re: Low beam not working [Re: Greg_Canada] #1012311 11/06/10 01:03 AM
4Crawler Offline
Well the head lights are switched ground, meaning the low beam terminal has a ground switched via the column dimmer (combo) switch. So if you do not see close to 0 volts at that terminal in low beam mode, that is your problem. In this case, 0 volts = good, 12 volts (or anything over 0.5 volts) = bad.
Re: Low beam not working [Re: 4Crawler] #1012312 11/11/10 02:43 PM
G
the wire corroded off where it clamps the plug, but didn't pull out because the wire wrap holder still held it in.
Pulled it all apart and soldered it back together, works like new.
89 4Runner
Re: Low beam not working [Re: Greg_Canada] #1012313 11/19/10 12:01 AM
Adam F Offline
I know you fixed it, but also there is a fuse for each headlight. I ran across this myself.
97 4R, stock, daily driver
Re: Low beam not working [Re: Adam F] #1012314 11/19/10 04:10 PM
G
Yup, popped those last year in the winter (oops?) then neither hi or low will work.
If it's either high or low not working... check the plugs!
Cheers,
Greg
89 4Runner
Re: Low beam not working [Re: Greg_Canada] #1012315 11/24/10 03:20 AM
Adam F Offline
Mine was weird....the headlight worked but was VERY dim...swapped it out and still dim. Replaced the blown fuse and all was good.
Re: Low beam not working [Re: Adam F] #1012316 11/24/10 02:58 PM
G
That's really weird... almost like the fuse still had a slight connection....
89 4Runner
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6285 MB (Peak: 0.7317 MB) Data Comp: Off Server Time: 2026-11-03 08:33:06 UTC
