Door handle
#1012386
11/07/10 12:53 AM
My dr side door handle has broken on the inside. I took it appart and found the cam snaped in half. Its plastic. I drilled a hole and pinned it back in place, also using super glue. Has held up so far. now it doesn't pop open when you lift the handle. You have to pull to open the door. Anyone else have this happen?
J-Bird
'95.5 T, SR5, Bone stock w/32x11.50's '06 Sonata LX
Re: Door handle
[Re: J_Bird]
#1012387
11/08/10 05:24 AM
It's common fer the door handles to break...especially if the rubber stops are gone and there's nothing to keep the handle from snapping on the door when you let go of it. <img src="/forums/images/graemlins/frown.gif" alt="" />
I modded mine with a nail fer support and 5 minute epoxy fer strength. I've got a post on here with piccies... <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5858 MB (Peak: 0.6337 MB) Data Comp: Off Server Time: 2026-06-12 11:53:25 UTCValid HTML 5 and Valid CSS
