Page 2 of 3 1 2 3
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012399 11/09/10 08:22 PM
leftnutt35 Offline OP
looked everywhere to see where it goes and i just can't seem to find where. any one got a SR and take the plastic cover off and look back there and see where it goes it almost straight down from the egr valve by the pcv if i got where that is right. on the passenger side .. thanks
95 SR stock but i hope not for long....
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012400 11/14/10 04:23 AM
Well after a friend of mine hopped on to the engine and looked back behind it he found the hose it had fallen off or was taken off at sometime in its life maybe while work was done to it but its been that way for at least 4 years or so. anyways after putting it back on it runs as smooth as a swiss watch.. no more bucking at hills smooth idle just great. but i need some advice as its getting cold and it sits over night it does not want to start takes like 4 times and putting the gas into it abit to get it started . after its started its fine . if you go somewhere then get in to restart it .it starts right up also. Not sure whats up there. battery is fine i was wondering if its my idle control valve that i bought used that i did not need that might be doing it. thanks guys for all the help...
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012401 11/14/10 06:12 PM
ECU ECT sender is bad, probably. Look for a 2wire sender with contacts in the shape of a T.
Re: Think i found the problem pic in post .. help needed [Re: fasteddy] #1012402 11/15/10 01:56 AM
FastEddy i am guessing you mean a Engine Coolant Temperature Sensor.
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012403 11/15/10 04:02 AM
Happy Birthday hazy_daze Offline
Yes indeedy <img src="/forums/images/graemlins/kewl.gif" alt="" />
The one listed at NAPAonline.com doesn't look right, but I've not done a CTS on a 3.5 SR yet, so it could be correct. The description he gave for the CTS (2 pins in T formation, usually coming straight forward near the turdmostat) is correct for a 3.0. Not sure if that's right for your 3.5. Maybe he'll chime in and clarify. I don't have ASA on this Netbook yet or I'd check myself. It definitely sounds like a viable culprit, and pretty inexpensive for a SWAG part toss.
Here's the NAPA page.
Re: Think i found the problem pic in post .. help needed [Re: hazy_daze] #1012404 11/15/10 09:07 PM
Well local branch said it should fit a 3.5 . and if it does not bring it back. will be in Tuesday.. Love my local NAPA store. now is there a procedure to take this out and put it back. manual shows where it is on my motor but zero on anything else.
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012405 11/17/10 01:08 AM
Ok got the sensor this evening do you put loc tight on it or grease or Teflon tape or what ?? thanks..
Re: Think i found the problem pic in post .. help needed [Re: leftnutt35] #1012406 11/17/10 01:27 AM
A little bit of Teflon tape will suffice.
Re: Think i found the problem pic in post .. help needed [Re: hazy_daze] #1012407 11/17/10 01:41 AM
thanks..
Re: Think i found the problem pic in post .. help needed [Re: fasteddy] #1012408 11/19/10 04:15 AM
3
3esso Offline
it is for sure the fuel pressure regulator vac hose
once i took mine for a spark plug change and when i got it back I took a look around for any shortcut he may have taken and i found this port the same as yours....
i took a deep look around and found the end of the vac hose sitting on top of the trans... it was the Blue stripped hose
I just got it (with a lot of time, it was sooo tight there) and reconnect it back
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6411 MB (Peak: 0.7497 MB) Data Comp: Off Server Time: 2026-06-23 04:50:27 UTC
