Re: Think i found the problem pic in post .. help needed
[Re: 3esso]
#1012409
11/20/10 03:22 AM
Yes i believe you are right on that one. Need to get it into the Garage this weekend and look around and grease it and i need to replace a idler pulley bearing also. will look more into it because i need to change it out the vacuum hose that is. now i changed the Engine Coolant Temperature Sensor and still starts real rough ect anyone else got any ideas. once its up and runnng its fine or if its warm it starts fine also.
95 SR stock but i hope not for long....
[Re: leftnutt35]
#1012410
11/20/10 03:28 AM
disco the battery and reset the computer.
[Re: fasteddy]
#1012411
11/20/10 04:20 AM
did that already when i changed it.
[Re: leftnutt35]
#1012412
11/20/10 08:54 PM
Do i need to just give it some time for ecu? . seems to be abit worse since i changed the fuel filter and the IAC .
[Re: 3esso]
#1012413
11/28/10 03:21 AM
I still can't seem to fix the problem with it not wanting to start when its cold. we got snow flying here lately and down into the teens some during the day and for sure in the morning. i go out in the morning to start it or anytime over night and it just does not want to start takes 3 or 4 times to get it to start . then it just stumbles about for a while. sounds crappy once it gets going. its fine once its been driven. its fine can start it like normal. any ideas guys..
PHP: 7.4.33 Page Time: 1.921s Queries: 16 (0.005s) Memory: 0.6133 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-07 01:20:20 UTCValid HTML 5 and Valid CSS
