Coolant leak is back. #1012414 11/07/10 04:08 AM
redbull Offline OP
Don't know if I posted about this earlier, but I had a pretty bad coolant leak last winter. Had 2 leaks in the rad and a bad thermostat gasket. All those issues were fixed, but I have a slow drip under the truck again!
Just ranting, hope the weather is nice enough tomorrow to have a look.
Re: Coolant leak is back. [Re: redbull] #1012415 11/08/10 05:28 PM
Pajerist Offline
Sorry to hear that!
Did you use chemicals to stop leaking last time?
The best way to fix it is to change leaking parts I guess...
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: Coolant leak is back. [Re: Pajerist] #1012416 11/08/10 07:53 PM
redbull Offline OP
No, I had the rad re-cored and cut a new gasket. Gotta get under the truck to see where the leak is, but all the stuff in the way makes it hard to see!
Re: Coolant leak is back. [Re: redbull] #1012417 11/10/10 08:02 AM
torquemonster Offline
my little o-ring that goes from the water pump to water pipe had a slow leak for over a year before i found it. just something the check! mine wasn't even a year old from when i did the timing belt and it started leaking.
PHP: 7.4.33 Page Time: 0.177s Queries: 15 (0.174s) Memory: 0.5977 MB (Peak: 0.6530 MB) Data Comp: Off Server Time: 2026-10-26 21:27:15 UTC
