head gasket is blown on my 91 Montero. #1012776 11/12/10 04:43 PM
canyonrc28 Offline OP
Should I get the head gasket fixed or just get another engine as the current one has 173 thousand on it?
I am a walrus.
Re: head gasket is blown on my 91 Montero. [Re: canyonrc28] #1012777 11/12/10 09:28 PM
hazy_daze Offline
At 173k, if all other systems are decent to good, I'd have the heads gone thru by a machine shop and rock on. Make sure you clean your deck real well and chase the head bolt holes with a bottoming tap.
Re: head gasket is blown on my 91 Montero. [Re: hazy_daze] #1012778 11/13/10 04:24 AM
and read "bob's 3.0 engine" for some very important points on head bolt length. I've been known to shorten up the head bolts a couple of threads just to be safe...
Re: head gasket is blown on my 91 Montero. [Re: canyonrc28] #1012779 11/13/10 04:33 AM
sasnydley Offline
I put new manufacture heads on mine at 240k. Now I have almost 270k. . Need to find out if coolant got into bottom of engine- Seems that the 3.0's tend to just blow out -not in.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-05-30 01:20:55 UTC
