Page 2 of 3 1 2 3
Re: Replace Rod Bearings [Re: fasteddy] #1013112 11/18/10 11:13 PM
hazy_daze Offline
And don't use a new Captain America penny for this...
Re: Replace Rod Bearings [Re: hazy_daze] #1013113 11/22/10 06:38 PM
89montero Offline OP
still haven't gotten a chance to take it apart.
How hard is it to remove the oil pan with the engine installed. I just took a look at the manual and it sounds like it wants me to pull the engine, first step is to remove the hood.
1989 Montero 4dr V6 3.0l
Re: Replace Rod Bearings [Re: 89montero] #1013114 11/22/10 07:21 PM
Remove crossmember and a couple of front diff carrier bolts and it comes off pretty easy, at least on the 3.0. 2.6 should be the same.
Re: Replace Rod Bearings [Re: fasteddy] #1013115 11/22/10 09:05 PM
oh thanks. was sounding like I'd have to lift the engine out a little ways to clear the axle.
Re: Replace Rod Bearings [Re: 89montero] #1013116 11/22/10 11:27 PM
well I got it all torn down, just about to pull the oil pan, hopefully it's not too bad in there.
Re: Replace Rod Bearings [Re: 89montero] #1013117 11/23/10 05:47 AM
Does anyone have any tricks for getting the oil pan off? I removed all the bolts but it doesn't want to come off, I assume it's just the gasket but I don' want to mess it up by prying too hard.
Re: Replace Rod Bearings [Re: 89montero] #1013118 11/23/10 08:47 AM
3
300D50 Offline
Plastic gift card under the gasket with carb cleaner works for me.
Work it around like a putty knife and it should get it all off. Follow up with a razor blade on the engine side and a brass brush on the pan itself.
Good luck!
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Replace Rod Bearings [Re: 300D50] #1013119 11/24/10 01:34 AM
MBrannon Offline
tap it around with a rubber mallet.
If the bearing has already spun, the crank needs to be turned or replaced.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Replace Rod Bearings [Re: MBrannon] #1013120 11/24/10 09:05 PM
I cut the side rail seal with a 6in1 painter/drywaller's tool, like a fancy putty knife with a paint roller cleaner halfround on the side, and a wide, edge sharp head, and a hammer. THe fsm shows a similar "special tool"...
THen I smack the side of the pan sump with a soft head hammer, or shield the metal with a piece of wood and smack that. It will pop loose.
Re: Replace Rod Bearings [Re: fasteddy] #1013121 11/30/10 09:18 PM
Got the pan loose. How do I actually remove it? Seems like the motor needs to come up like 5" before the pan can clear the front axle and slide out.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6383 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-05-29 15:43:02 UTC
