will pitman arm for 92 montero fit 91 pajero? #1014779 12/09/10 05:46 PM
tengopajero Offline OP
After a partial brake failure on my 91 pajero( turned out that the left rear brake disk had completely disintegrated, with attendant fluid loss from the wheel cylinder, a suspension check revealed that I also need a new pitman arm. Will a 92 montero pitman arm fit or does the right hand drive on the pajero mean that I need to order an imported one?
many thanks in advance for your answers/advice.
John
Re: will pitman arm for 92 montero fit 91 pajero? [Re: tengopajero] #1014780 12/10/10 02:35 AM
PHIL_ Offline
It will fit. I used a Monty spec'ed unit on my 91 Paj 3 years ago, and it is still on there AFAIK...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5873 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-06 19:14:42 UTC
