How should i clean this #1015044 12/11/10 11:57 PM
mitsumonki Offline OP
after a few hours of head scratching i found this.
truck backfires a lot and has no power
Re: How should i clean this [Re: mitsumonki] #1015045 12/12/10 01:38 AM
WD40, a points file, and a cotton swab.
Re: How should i clean this [Re: rxinhed] #1015046 12/12/10 03:45 AM
StockRaider Offline
buy a bottle of electrical connector cleaner and a few brushes. After that fill the plug ends with electric tune up grease.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: How should i clean this [Re: StockRaider] #1015047 12/12/10 04:56 AM
3
300D50 Offline
Seconded.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: How should i clean this [Re: 300D50] #1015048 12/12/10 04:41 PM
Yeah i did as you guys suggested and made this super awesome cleaner(out of a wiperblade)
Still runs like crap....
Oh and that was a spare ECM. I had the stock one repaired.
That one was just plugged in as the truck sat for 8 months.
[/list] [Linked Image]
Re: How should i clean this [Re: mitsumonki] #1015049 12/12/10 04:43 PM
Was it able to remove that oxidation so you're back down to bare metal?
Re: How should i clean this [Re: off-roader] #1015050 01/07/11 03:49 PM
Yeah, I cleaned the crap out of it. Still had the same problem so I replaced the connectors.(PITA) Still the same problem. Tried another ECM and still wont accelerate properly.
*Roll diagnosis dice*
Pull fuel rail check/swap injectors
Re: How should i clean this [Re: mitsumonki] #1015051 01/07/11 07:40 PM
W
willwinchforfood Offline
or check your timing per the manual first?
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
PHP: 7.4.33 Page Time: 1.708s Queries: 15 (0.004s) Memory: 0.6220 MB (Peak: 0.7010 MB) Data Comp: Off Server Time: 2026-06-13 02:12:01 UTC
