Roof rack feedback needed
#1015175
12/13/10 06:59 PM
So, I've always liked the xterra roof rack, so I cut one down to see what it would look like. What do you guys think? I'm kinda on the fence.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
Re: Roof rack feedback needed
[Re: zarktheshark]
#1015176
12/13/10 07:10 PM
its alright but I think I like the normal setups better/ Really only your opinion counts though.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe 87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
[Re: airbats801]
#1015177
12/13/10 07:25 PM
The X-Terra looks nicer but they both still rely on the roof for support. I think the best racks are the ones with a basket that gets the load off of the roof itself.
Every have a bunch of luggage strapped to the top of a Gen II.......the sunroof doesn't like to open very well. <img src="/forums/images/graemlins/wink.gif" alt="" />
96 Montero LS 24V DOHC 3.0L. 98 Montero 24v SOHC 3.5L, factory rear locker, Winter/tow package. 63 Jaguar XKE 3.8L FHC 2000 Mercedes-Benz e430 07 fj cruiser
[Re: cmonty72]
#1015178
12/13/10 07:44 PM
I agree that it will not support the weight of a gutter mount. I don't really plan on putting much weight up there. I plan on putting some plates under the roof to help with weight distribution. In the end, it is really for looks and maybe to put some lumber. I have my full size truck for major stuff.
[Re: zarktheshark]
#1015179
12/13/10 11:13 PM
A roof rack will cost you mileage empty or loaded. I like my Yakima because I can take it off. It tends to get in the way in some of the places I camp so pulling a small trailer works better for me.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
[Re: zarktheshark]
#1015180
12/14/10 04:36 AM
I thinkit looks pretty good. Does it sit flush where it mounts to the roof? It works with the roof contour, so astethically it is acceptable. If you like it, to he11 with others opinions. If it'll work for what you want, then knock yourself out and use it!
[Re: Mudraider]
#1015181
12/14/10 04:56 AM
the mounts do sit flush, but the raider only has about a 1in rise in the back and the xterra has a 2in. So I will need to fab up an extention or spacer for the middle and back feet. in the pic, I have a 3\4in piece of wood as a spacer. Nothing is bolted down, no holes drilled yet, just dry fitting it. I also cut out about 16in of pipe to get it to fit on the truck.
[Re: zarktheshark]
#1015182
12/15/10 12:26 AM
Sounds like a simple fix. I'd go for it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: zarktheshark]
#1015183
12/15/10 03:20 AM
Can these roof racks serve as ladder racks? I don't really need to put any on the roof, other than a ladder from time to time.
[Re: bar2hunter]
#1015184
12/15/10 04:18 AM
I haul my 28'extension and two 8'step ladders on my Gen 2s with no issues.
