Page 4 of 4 1 2 3 4
Re: Hard starting question [Re: bingocouple] #1015622 12/31/10 05:45 AM
DamKia Offline
Kia Moderator
If your ground wire is getting hot then it is passing more than enough current. My thinking is to start with he starter motor, If it is slow and drawing excessive current then I would be getting that looked at. Suspect brushes or armature needs to be regrooved or possible shorted turn in the motor..
Re: Hard starting question [Re: DamKia] #1015623 12/31/10 07:39 AM
bingocouple Offline OP
ok thank you. I have to start my work week early this week so I will puill the starter next wednesday and take it in and will have it checked out. Thanks again.
Re: Hard starting question [Re: bingocouple] #1015624 12/31/10 08:55 AM
Sportege_Panicmech Offline
<img src="/forums/images/graemlins/confused.gif" alt="" /> Good ground wires do not smoke generaly. Shouldn't be any smoke within the first 10-20 sec at least.. Smoke usually means theres a restriction of current. That's the definition of a light bulb. Put 55watts through a strand of wire and take the oxygen out to prevent the wire from burning basically. High current through a restricted connection.
When you added a second battery did you just put the clamps on the battery posts.. that only adds current to what sounds like a bad ground cable. Might want to have a buddy crank it again to make it smoke and see where the smoke comes from. Then inspect the source of the smoke.
So my suggestion before you pull the starter. Leave the red clamp on the (+) battery post and but the black clamp on the engine block itself.. Good spot might be the engine's hoist hook. A clean bolt or something. The point is to supply ground DIRECTLY to the engine rather than through your existing ground.. Do this and if the starter fires up better and the engine fires up sooner then you have a bad ground 100%!! I've seen this before plenty. At least try this 5 minute check before you go getting greasy pulling a starter. I'd say if it doesn't change then you'd want to pull the starter and bench test it.
It's very rare nowadays, but a sometimes a starter can indeed have a shorted winding. which will increase the amp draw, yet it's power to the flywheel will be decreased which could result in a smoking good ground.
Sux that she's givin you this much grief. I pass a sportage sitting for sale in a lot everyday and it's covered in a foot of snow.. poor little sportage. Wife tells me no when we pass it. She's right. I don't need another, but it's sad to see it there all cold n' lonely <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Hard starting question [Re: Sportege_Panicmech] #1015625 12/31/10 04:14 PM
I just checked out your videos, does your sportage have the stock motor? Sweet ride, I wish mine ran that well with all the power.
Re: Hard starting question [Re: bingocouple] #1015626 01/01/11 05:06 AM
Stock motor. I've been beating every day for 5 yrs. Stout Motor! Burns oil now. I add a quart about every week or two. I work in a shop so that's not a big deal. I made my own short ram air intake with cone filter, gutted the 2nd Catalytic converter (after the 2nd 02 sensor). Put a knock off flowmaster on it and am in love with the sound of it! Also played with intake cam timing, but i think i'm happy with it stock though. Don't be afraid to use the high rpms. that's where the power is. around 3-5k.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6131 MB (Peak: 0.6952 MB) Data Comp: Off Server Time: 2026-05-27 21:11:33 UTC
