Page 4 of 11 1 2 3 4 5 6 10 11
Re: Hunting Rifle Mission Creep [Re: Jim_Paget] #1015907 01/04/11 06:46 AM
kewlynx Offline
I am sure whether the crankiness comes from being a gunsmith or if it is a prerequisite.
I wonder that about old beekeepers too. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Nice work Frank; gotta love it.
**ubi apis- ibi salus**
Re: Hunting Rifle Mission Creep [Re: kewlynx] #1015908 01/05/11 01:57 AM
LandRaider Offline
Heck yeah nice work!!!
Re: Hunting Rifle Mission Creep [Re: kewlynx] #1015909 01/05/11 01:59 AM
hazy_daze Offline
No kidding. My Pappy (kind of my adopted grandpa) was cantankerous as hell, but I learned alot about life helping him with his bees.
Watching all the progress on this is very interesting, Frank. Keep up the fine work <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Hunting Rifle Mission Creep [Re: hazy_daze] #1015910 01/05/11 02:51 AM
Jim_Paget Offline
Well, I have a new issue to attack tomorrow. I bought a set of long rings today for the Mauser. They were almost long enough. The bolt doesn't quite clear the scope. The mounts are Weaver style. I need to find a thicker mount or a shim.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Hunting Rifle Mission Creep [Re: Jim_Paget] #1015911 01/05/11 12:54 PM
FrankR Offline OP
Jim, the bolt clearance with a Springfield is resolved by using a bent bolt handle - not sure about the Mauser. If the clearance is minimal, you can use taller rings. If you only need a few thousandths clearance, a snip of beer can metal will usually work.
Frank
Re: Hunting Rifle Mission Creep [Re: FrankR] #1015912 01/05/11 05:17 PM
FrankR Offline OP
I took a look at some Mausers and confirmed my suspicion - you need a different bolt handle to clear a modern scope with a large eyepiece and anything other than very high mounts. Here's a link to something you can use as an idea of what to do - I haven't researched the best option for Mausers and there may be a better alternative:
web page
My advice (FWIW) would be to change/alter the bolt handle in order to keep the scope as low as possible. About 1.5" between the bore center and scope center is about right. I've set up my 1903 at 1.75" because of the 1-piece mount and I sure wouldn't want the scope any higher.
You'll need to identify which Mauser action you have if you order something ready-made - or you can bend and grind it yourself. Here are some DIY instructions:
web page
Frank
Re: Hunting Rifle Mission Creep [Re: FrankR] #1015913 01/05/11 07:52 PM
Jim_Paget Offline
My Mauser already has a bent bolt handle. It probably is as tightly bent as possible. It fits very close to the stock. Most Mausers use a special mount system that has a bridge between the front and rear mounts. I have that type of mount on Voere. The Mauser came with standard Weaver type mounts and I put long rings on those, but the bolt just doesn't quite clear the scope.
I am going to try to make a couple of shims to see if that will work. If not, I will order the Mauser specific mount as soon as I can identify which model of Mauser I have. The marks that are usually used to identify the type of Mauser have been removed from this receiver.
Jim Paget
www.rrr4x4.com
Re: Hunting Rifle Mission Creep [Re: Jim_Paget] #1015914 01/06/11 10:11 PM
Jim_Paget Offline
Well, I resolved the issue today. I found some rings that are longer and they work perfectly. I have lots of clearance.
I also picked up slings for the .270 and the 30.06. We are ready now to head to the range, first to bore sight the rifles and then to sight them in. I am really interested to see how each of them shoot. Two of them, the Savage 30.06, and the .300 Win Mag have reputations as tack drivers. I suspect that the .270 should do fine, also.
I do have a recoil pad coming for the Savage.
Jim Paget
www.rrr4x4.com
Re: Hunting Rifle Mission Creep [Re: Jim_Paget] #1015915 01/06/11 11:08 PM
FrankR Offline OP
Wuss! <img src="/forums/images/graemlins/lol.gif" alt="" />
Glad you found a good solution. It's certainly less trouble to raise the scope. Make sure you still get a reasonable cheek weld.
Frank
Re: Hunting Rifle Mission Creep [Re: FrankR] #1015916 01/07/11 12:04 AM
Jim_Paget Offline
Well, the problem was your fault, Frank. I hadn't done anything to the Savage yet.
Jim Paget
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6522 MB (Peak: 0.7778 MB) Data Comp: Off Server Time: 2026-05-29 23:41:08 UTC
