285/60/16 on a stock Gen 1? #1016008 12/24/10 12:01 AM
W
WagonMaster Offline OP
Did a search, and checked the FAQs. Didn't find a "Here's what fits." guide.
Will they rub, either width or height?
Thanks
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: 285/60/16 on a stock Gen 1? [Re: WagonMaster] #1016009 12/24/10 12:08 AM
Thanks
I assume you don't know how to calculate what those numbers mean in terms of tire size?
285 is the tread width in mm.
60 is the 'aspect ratio' which means the sidewall height = 60%x285mm=171mm=6.73"
6.73"x2 (top side wall + bottom side wall) + 16 (rim size)= 29.46".
HTH.
That's essentially a 29" tire which is pretty much the STOCK tire size. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 285/60/16 on a stock Gen 1? [Re: off-roader] #1016010 12/24/10 12:23 AM
W
I did know that it was a little over 29", but I'm running a 235/75/15 currently, and I didn't know if the extra 1" (or so) of height would be too much difference for the stock suspension.
More importantly, the extra 50mm of width seems to be the difference between a 6.5" wheel and an 8.5" (if my math is right). That 2" of width is (proportionally) MUCH bigger than the 1" of height.
Re: 285/60/16 on a stock Gen 1? [Re: WagonMaster] #1016011 12/24/10 12:39 AM
It's roughly a 11x29, and should fit just fine, since 10.50-31-15's fit
Re: 285/60/16 on a stock Gen 1? [Re: WagonMaster] #1016012 12/24/10 12:52 AM
No problem and thanks for noting there is no thread in the FAQ post on tire sizes. I'll certainly have to rectify that soon. It's probably one of THE TOP 5 MOST asked questions. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 285/60/16 on a stock Gen 1? [Re: off-roader] #1016013 12/24/10 01:52 AM
W
Thanks for the info, guys! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I found a set of wheels that will go great with my Raider plans, I just didn't want to buy them before checking for fit.
Re: 285/60/16 on a stock Gen 1? [Re: WagonMaster] #1016014 12/24/10 01:56 AM
ryany Offline
http://www.miata.net/garage/tirecalc.html
I've used this tire size calculator for years - gives great comparisons for tire sizes.
95 Montero SR
Re: 285/60/16 on a stock Gen 1? [Re: ryany] #1016015 12/24/10 04:05 AM
W
I like that the calculator even feeds the speedometer correction information. Mine reads about 2 mph faster than my GPS claims, and these new tires will pretty much correct for that.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6228 MB (Peak: 0.7178 MB) Data Comp: Off Server Time: 2026-06-02 18:04:52 UTC
