Re: Gen 1 6g72 has no spark on cyl #2. ideas? [Re: FrankR] #1016369 01/02/11 03:54 AM
sasnydley Offline
was the ENTIRE distributor replaced as in The optical pick-up Under the cap and rotor? as in the whole mechanism? What yr truck is this?
Re: Gen 1 6g72 has no spark on cyl #2. ideas? [Re: sasnydley] #1016370 01/02/11 07:13 AM
StockRaider Offline
Have you tried testing spark using a plug wire from another cylinder? Plug wires, even new can be bad from the factory. It just happens sometimes, also the little metal connector inside the plug boot can pull off the wire enough to cause weak spark, happened to me twice.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5937 MB (Peak: 0.6421 MB) Data Comp: Off Server Time: 2026-06-17 08:00:37 UTC
