Re: Gen 1 6g72 has no spark on cyl #2. ideas?
[Re: FrankR]
#1016369
01/02/11 03:54 AM
was the ENTIRE distributor replaced as in The optical pick-up Under the cap and rotor? as in the whole mechanism? What yr truck is this?
[Re: sasnydley]
#1016370
01/02/11 07:13 AM
Have you tried testing spark using a plug wire from another cylinder? Plug wires, even new can be bad from the factory. It just happens sometimes, also the little metal connector inside the plug boot can pull off the wire enough to cause weak spark, happened to me twice.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5929 MB (Peak: 0.6410 MB) Data Comp: Off Server Time: 2026-06-18 17:04:33 UTCValid HTML 5 and Valid CSS
