Anybody know anything about Perkins Diesels?
#1016429
12/29/10 05:19 AM
A guy at work recently picked up a freebie Nissan hardbody pickup chassis, and was telling me his plans for a wheeler. He was telling me about these Perkins motors that are used in all the berry pickers in our area and can picked up for near nothing. Says swaps are pretty straightforward. I did a little poking online, but wondered if you guys had any info.
-Dave D Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..." -Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Anybody know anything about Perkins Diesels?
[Re: ForcedAir_Montero]
#1016430
12/29/10 06:02 AM
Possible SWB montero motor?
[Re: Kevin C]
#1016431
12/29/10 06:25 AM
ya, if I can't do something serious about fuel economy, the monty will have to go.
#1016432
12/29/10 07:10 AM
Time to share some beer and brats with one of those berry pickers who might have one of those mills installed already.
Take pix!
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
#1016433
12/29/10 07:44 AM
Kia Moderator
Very heavy and relatively underpowered
520kg for 130kw (175 HP) and these things can only max out to 2800 rpm. Bags of torque though but also very large in size.
They are designed for long life, low maintenance, constant RPM tasks.
All in all not a good candidate. Info gained from their website so the engines you are talking about are the less hi tech versions of those (ie heavier/less power/larger)
[Re: DamKia]
#1016434
12/29/10 08:07 AM
you're close enough to canada right? find a guy with a cheap enough pajero diesel and swap the goodies since we aren't allowed to have the actual trucks here. <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#1016435
12/29/10 08:33 AM
True enough; we have lots of Paj guys here, many directly north of you.
[Re: kewlynx]
#1016436
12/29/10 05:44 PM
Yeah those engines will be too underpowered for the montero, they are likely designed to run all day at 2 different RPM ranges one for idle and one for working. If these berry pickers drive themselves (not a tow behind deal) still would probably need a different cam and injection pump to make it streetable. Your best bet is finding a Pajero engine if you want fuel economy, otherwise you'll be looking at probably a loss.
[Re: TOASTY]
#1016437
12/30/10 03:19 PM
[Re: fasteddy]
#1016438
12/30/10 03:43 PM
And then bigger springs or torsion bars...
