Re: 1988 Pickup Temp gauge help [Re: 4Crawler] #1016596 01/06/11 08:30 PM
toyomorph Offline
the wires on the sensor should be in a plug and should be really easy to disconnect. It's the first sensor on the front of the intake manifold. Ther is a procedure for checking it in the 1985 FSM that is available for download here in another sticky thread near the top of the main page. It is on page FI-68 in the EFI section. There is also a procedure for removing the combination guage to get to the temp gauge in the FSM. I suggest you download it as there isn't too many serious changes from 85 to 88. It will be very applicable. I pulled my combo meter in less than 20 minutes yesterday. A Haines manual also has the info. If I can figure out how to copy a .pdf pic from the FSM and post it I will, but don't know how yet.
Here's a pic of where the sensor is on my 93 and it's in the same location on your 88, but might appear a tad different.
btw Roger that was excellent info in that link you provided - thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
canyon country explorer
1993 4x PUP
Re: 1988 Pickup Temp gauge help [Re: toyomorph] #1016597 01/09/11 10:26 PM
Tcloud Offline OP
Thanks for all the help and good info. I found it. Its on top of the motor next to the thermostat housing. I replaced the sending unit and now its working fine.
Don and Barb
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5944 MB (Peak: 0.6433 MB) Data Comp: Off Server Time: 2026-06-20 13:43:15 UTC
