Re: 02 sporty running hot [Re: Everet] #1016637 01/10/11 09:31 PM
logansportage Offline
We should all chip in and get Everet a week's pass at AA the next time he needs to do a complete fluids change. That way he can recover from his weekend of wrenching <img src="/forums/images/graemlins/angry.gif" alt="" /> and boozing <img src="/forums/images/graemlins/cheers.gif" alt="" />.
Gust giving you crap bud. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: 02 sporty running hot [Re: Everet] #1016638 01/11/11 01:17 AM
DennisThompson Offline
Where did you get your gauge pod? I want one <img src="/forums/images/graemlins/smile.gif" alt="" />!
Dennis
Re: 02 sporty running hot [Re: DennisThompson] #1016639 01/12/11 10:16 AM
2002_Sporty Offline
x2 on the Pods,
Everet has all kinds of stuff done to his Sportage. It's only on occasion that we get to see those custom mods.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: 02 sporty running hot [Re: 2002_Sporty] #1016640 01/13/11 06:29 AM
Sportege_Panicmech Offline
x3 on pods, lol. but i can't get pods unless I has turbo! It's a personal restraint and mild motivator. I really don't have a need for 3 gauges on a n/a OE block. I would definitely have a need on a turbo'ed OE block!! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: 02 sporty running hot [Re: Sportege_Panicmech] #1016641 01/13/11 06:57 AM
fokion Offline
Its ok and on a single base.....
green led lights when there is power to the elec fan cirquit, orange when the relay sends current to the fan
an a more clear one but in an unfinised stage
Re: 02 sporty running hot [Re: fokion] #1016642 01/15/11 04:12 PM
Everet Offline
Do a search on ebay for 52mm UNIVERSAL BENDABLE TRIPLE GAUGE A PILLAR POD
I painted it with a grey that was close.
Removed the stock pillar cover, drilled a hole in it for the wires and JB welded the pillar pod to it and then filled in the gaps, sanded it and touched up the filler with some grey paint.
If you want a tight fit on the ends, you might try and heat the pod end carefully with a heat gun. Since the pod is ABS, you should be able to form it to the contour of the stock pillar cover. I will do that on the next one.
For the one on the dash, I just used a 52mm UNIVERSAL TRIPLE DASH GAUGE HOLDER MOUNT POD METER
I didn't like how it turned out because its surface isn't textured but it works.
I'm going to do my 2 door gauges with the pillar pod so I will try and document with pics in a new thread.
Everet
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6163 MB (Peak: 0.7019 MB) Data Comp: Off Server Time: 2026-06-07 09:05:42 UTC
