Page 2 of 3 1 2 3
Re: Interior mods, what would you do? [Re: Spook] #1016664 01/02/11 10:52 PM
Bernoulli Offline
I'd make a new dash (out of teak to match my other small mods) extended to include the oil pressure, voltmeter and useless gauges (replaced with 4 better gauges.)
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Interior mods, what would you do? [Re: Bernoulli] #1016665 01/02/11 11:37 PM
L
LeeForget Offline
cup holders is definitely a requirement...im going to mod the dash itself to accept bottles/cans. i smashed off my voltmeter/inclinometer/???meter because only the inclinometer actually worked due to the wiring being missing.....it was there on the back on the gauge cluster but wasnt there on the vehicle. i guess it was added on? anyways, its sitting under my seat or something. other than that i swapped out my seats, that were not original, since i couldn't get in the back seat(its a 2 door, im assuming it had 4 door seats) with chevy cavalier coupe seats. Thats about the extent of my mods inside the cabin that dont require the use of a hammer.
Re: Interior mods, what would you do? [Re: LeeForget] #1016666 01/03/11 04:40 PM
heathdogg Offline
The wiring for the cluster is behind the plastic plug the is right behind it. Mine came without the cluster, but the wiring was still there. Just had to change the oil send to a guage type instead of the light.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Interior mods, what would you do? [Re: heathdogg] #1016667 01/03/11 05:35 PM
Jamez Offline
Did soemone swap a Gen2 dash into a Gen1 or was that just seats?
Re: Interior mods, what would you do? [Re: Jamez] #1016668 01/03/11 06:32 PM
hazy_daze Offline
SRTNate is in the process of doing so. He may be done by now...
Re: Interior mods, what would you do? [Re: hazy_daze] #1016669 01/03/11 07:27 PM
RECON45 Offline
Here is my cupholder I got from a jeep cherokee. fits nicely in the Gen 1
Re: Interior mods, what would you do? [Re: heathdogg] #1016670 01/03/11 09:50 PM
L
LeeForget Offline
i tried looking for it but i couldnt find it. ill look again eventually. Thanks.
~88 Raider 2.6L 5 speed
~35"x14.5"r15
~SOA(Spring Over Axle)
~TT(Torsion Twist)
~SBL(Sloped body lift)
Re: Interior mods, what would you do? [Re: LeeForget] #1016671 01/03/11 11:11 PM
heathdogg Offline
If someone has removed the dash, the connector may have fallen down and is wedged behind the wiring or the dash. I did that, but haven't fixed it.
Re: Interior mods, what would you do? [Re: RECON45] #1016672 01/04/11 02:48 AM
Spook Offline OP
Hey, that's great. I did see a side mounted type but it had a longer side, guess it could be cut down like that....thanks for the pic
Any other pics???? Post em up!
Re: Interior mods, what would you do? [Re: Spook] #1016673 01/04/11 03:31 AM
bar2hunter Offline
So far, I've replaced rear carpet and added some added seat options...
Some more seating/storage options (Plano box is velcroed to carpet)...
Folds down to get to spare tire jack...
Also added some rear cargo lighting, for when I open the door...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6397 MB (Peak: 0.7475 MB) Data Comp: Off Server Time: 2026-06-07 05:59:37 UTC
