Re: Turning radius is balls
[Re: LeeForget]
#1016807
01/03/11 05:04 AM
Are you sure that your 35"s are allowing you to hit the steering limiters when you turn?
[Re: Kevin C]
#1016808
01/03/11 05:43 AM
Are you sure that your 35"s are allowing you to hit the steering limiters when you turn? 36's and the Lugs on my swampers kiss the leaf springs, but yes... they are hitting the locks on each side.
[Re: LandRaider]
#1016809
01/03/11 06:11 AM
i think he was talking to me.
i dont have my 35's on yet, still have my 31's on there. i checked to see if their rubbing the frame/body at all and their not even close.
~88 Raider 2.6L 5 speed ~35"x14.5"r15 ~SOA(Spring Over Axle) ~TT(Torsion Twist) ~SBL(Sloped body lift)
[Re: LeeForget]
#1016810
01/03/11 01:09 PM
I turned the stops way in on my 87. It turns a lot tighter but yo need to use a very light touch with your hands at the limit. The CVs at ride height have more travel available allowing a tighter turn but as soon as one wheel drops they will bind up. You need to feel for this when driving. If you just turn to the limit and hold it there with the stops adjusted back and drive over terrain the next clunk you hear will not make you happy.
[Re: OldColt]
#1016811
01/10/11 03:15 AM
funny, I was just thinking that....
yeah, honestly, I'm always surprised when I get into a different car, crank the wheel over- and hey, wow, this thing will turn sharp!
The LWB is even worse- well, it's longer!
heh
e
'89 V6 4dr- '4- Doris'
