Valve build up #1016936 01/04/11 01:22 AM
RyanB Offline OP
I have a lot of build up on the exhaust valve on number 4 cylinder. Should I worry about this? I don't really have the money to rebuild the entire head, but I could replace the exhaust valves.
When I removed the piston it was cracked in 3 places and basically fell out of the cylinder. So I assume it had oil pouring into the cylinder. The block and cylinders were surprisingly in fairly good shape, I dropped it off to be honed and new pistons and rings installed.
Any advice is appreciated,
Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: Valve build up [Re: RyanB] #1016937 01/04/11 12:06 PM
E
Engine_Machine_Ser Offline
You could wire brush that off, Be sure thats not a crack between the valves.
Randy
Re: Valve build up [Re: RyanB] #1016938 01/04/11 04:46 PM
Roll the cam and get each valve to open and visually inspect the seating area for pitting and any other issues. If they look decent, run it. What I see is an oil buildup and since you had a known failure you do not need to go far to find an oiling issue.
Re: Valve build up [Re: OldColt] #1016939 01/04/11 05:45 PM
I concur. I'd scrape/wirebrush/clean the vavle head if the seats and valve seat contact ring is clean and tight, just to get rid of potential hot spots that could cause preignition. I didn't see a problem crack. If there wasn't an incipient crack there, I'd worry...
Re: Valve build up [Re: fasteddy] #1016940 01/04/11 11:52 PM
RyanB Offline OP
Thanks everyone! I will wire brush it clean and inspect to make sure there are no cracks.
I was hoping that would be your answer, my block will cost me about $600 by the time I get it out of the engine shop. But still - I should have a good running Montero for a little over $1200 total.
Thanks again,
Ryan
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-06-10 01:26:53 UTC
