Re: which rear axles will fit my sporty?
[Re: DennisThompson]
#1017002
02/01/11 11:42 PM
Dennis,
That's the one I'm looking for too.
#1017003
02/02/11 12:53 PM
My boys friend had a Miata with the rear LS and you could feel it engage if you gave it a little juice going around a corner, thats the one I want in my front dif but they seem to be spendy, I think it was the Torsen LSD. I have the extra dif for when I find one though. I was thinking about a Torsen diff at one point, but I read somewhere that a Torsen ends up acting just like an open diff if one wheel is off the ground, so that's not the best solution for off-roading. I've been eyeing that Kaiser locker lately. Seems to be an intriguing design, though a bit pricey.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
[Re: Dryver]
#1017004
02/03/11 01:22 AM
Most limited slips do that, if they slip just tap on the break and they usualy lock up. The Ranger FX4 Level II had the Torsen and I've heard they work great in that. Anyway right now spendy is out of the question, any extra money goes to my 61 F100.
Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
#1017005
02/03/11 04:42 AM
mine already has a limited slip diff- a factory fitted one- not that great. a read that detroit lockers also makes a 28 spline rear LSD. i am stil checking out the option of fitting spacers in the diff to make it lock up the wheels faster
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock. http://www.cardomain.com/ride/3948684/2001-kia-sportage
[Re: hadtomer]
#1017006
02/03/11 12:53 PM
The rear LSD made a huge difference in my Sporty. I used to just sit and spin one wheel on a slick corner when starting from a stop. Sometimes even if it was just wet. Now I'll fishtail if I'm not careful (or sometimes intentionally).
[Re: Dryver]
#1017007
02/04/11 01:52 AM
When the weather warms up a bit and my garage gets above 10 degrees I will get some pics of the spacers I put in my LSD before I install it, I got an invite from some guys at work to go to Moab with them in a few months, I want to have it in by then and I can tell you how it works. They have some realy nice built TJs, Rubicons, a few YJs and a realy nice Bronco so it should be real fun.
Dennis
#1017008
02/04/11 04:56 AM
Dennis,
When you going? Send me a PM. I need to get down to Moab too and it would be fun to crash your party. Then there would be two white KIA Sportages showing those Jeeps how it's done again. Do you remember the first time we went the dorks in Jeeps with 33Æs that were having problems getting up Poison Spider? You just pulled up to the same obstacle and went right up and over without even spinning a single tire.
#1017009
02/04/11 07:03 AM
what kind of lsd do you have? mine is a factory fitted one.
[Re: hadtomer]
#1017010
02/04/11 09:45 AM
This comment is intentional hate mail. <img src="/forums/images/graemlins/nana.gif" alt="" /> Directed at you guys with factory LSD's. I have one wheel drive. <img src="/forums/images/graemlins/frown.gif" alt="" />
2002 4dr Kia Sportage 4X4 Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
[Re: hadtomer]
#1017011
02/04/11 01:17 PM
what kind of lsd do you have? mine is a factory fitted one. Mine is the Kia LSD from a dealer, just installed late in life.
