Page 3 of 4 1 2 3 4
Re: Drive shaft problems?? [Re: plh] #1017040 01/07/11 09:16 PM
RockU Offline OP
Nope, Raider front axle.
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Drive shaft problems?? [Re: plh] #1017041 01/08/11 03:23 PM
RockU Offline OP
[img]http://www.flickr.com/photos/33691567@N08/5335367255/[/img]
Here's a drafting picture giving my measurements.... I don't have a clue which shaft this is (V6 or 4I)??
Re: Drive shaft problems?? [Re: plh] #1017042 01/08/11 04:01 PM
RockU Offline OP
Trying this again...
<a href="http://www.flickr.com/photos/33691567@N08/5335367255/" title="ShaftDrawingFinal by jondanderson, on Flickr"><img src="http://farm6.static.flickr.com/5047/5335367255_70f59f3b47.jpg" width="500" height="321" alt="ShaftDrawingFinal" /></a>
Re: Drive shaft problems?? [Re: plh] #1017043 01/08/11 04:03 PM
RockU Offline OP
Re: Drive shaft problems?? [Re: RockU] #1017044 01/08/11 06:24 PM
plh Offline
You must be signed in to see this content - error at flicker
Here is your photo:
Here is the fix: you need a V6 Manual drive shaft. I don't have a spare.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Drive shaft problems?? [Re: plh] #1017045 01/08/11 08:47 PM
The shafts that I have extra measure 25.25" in this measurement.
Re: Drive shaft problems?? [Re: RockU] #1017046 01/08/11 09:11 PM
Kevin C Offline
I don't profess to be an expert, but I know I do my homework so here's what I purchased and it dropped right in!!
The 87 Starion rear diff fits the V6 Montero / V6 Raider front diff if you use the the 4 cyl CV joints. You also need to mod the cross member to get the pinion mount to fit.
Three versions of the front LSD swap were figured out.
The first was by a guy in AZ... Forget his name ( Mitsutech). That was the early Starion LSD into a 4 cyl diff.
The second appears to have been done by Kary, that was done by using the 87 Starion LSD and 4 cyl axles.
The third version was to use the 88-89 Starion LSD with the V6 CV joints. Some guy from California named Kevin worked that swap out.
It sounds like you have the swap Kary worked out.
I have had everyone of these parts for every version of this swap on my workbench at one time or another.
Someone would have had to swap the diff housing from a V6 into your 4 cyl... Or you have a V6 Chassis. I'm assuming you have leaf spring in the back?
Re: Drive shaft problems?? [Re: Kevin C] #1017047 01/09/11 02:32 AM
RockU Offline OP
LOL, yes I do, but don't have a clue about frame type, any previous swaps, etc.,.. I purchased it from the original 1st owner who said it's an all Arizona vehicle but had California smog emissions on it. PLH just told me that he didn't have an extra V6 front drive shaft to send me... I'm on the hunt again....
Re: Drive shaft problems?? [Re: rxinhed] #1017048 01/09/11 02:35 AM
RockU Offline OP
Hey Russ, PLH and Kevin said I need a V6 front drive shaft to fix my problem. Do you have any I can purchase from you? Would even send you mine with any extra cash you might need? Just PM or email me... Thanks...
For reference, you can see the photo's I tried posting to PLH.... Thanks much!
Re: Drive shaft problems?? [Re: RockU] #1017049 01/09/11 02:49 AM
What they stated was that you need a V6 stick shift front shaft, and I am saving this piece for a conversion on my Raider...which is why I didn't mention having one. I do have two 4-cyl front shafts you can have, but no 6-cyl pieces.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6482 MB (Peak: 0.7541 MB) Data Comp: Off Server Time: 2026-06-17 13:19:11 UTC
