Page 4 of 4 1 2 3 4
Re: Drive shaft problems?? [Re: rxinhed] #1017050 01/09/11 03:12 AM
plh Offline
The shafts that I have extra measure 25.25" in this measurement.
This is the same length as my V6 Stick driveshaft.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Drive shaft problems?? [Re: plh] #1017051 01/09/11 07:41 PM
Ok then. I have some shafts that may work for you, but with bad (rusty) slip shaft parts.
Re: Drive shaft problems?? [Re: rxinhed] #1017052 01/10/11 01:48 PM
RockU Offline OP
Yes I understand - I wasn't sure if you were referring to both or just only the 4 cyl one. Thanks for the info. I'm on the hunt for the V6 front drive shaft....
RockU - Federal Way, WA - 1989 Montero, New-2.6L, New-5spd, New Clutch, header, 10x15 wheels, 32x11.5x15 Mud Claw (Cardovan), 4" lift, Superwinch Hubs, Front LSD, Synch 38/38 Weber Carb, K&N filter, (Let's hit the trail!) Home Email: jondanderson2002@yahoo.com
Re: Drive shaft problems?? [Re: plh] #1017053 01/11/11 02:57 AM
This means the two shafts that I have, sourced from a 4-cyl stick shift, not the V6 one I'm not letting go of, may be the correct shaft for your application. <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6657 MB) Data Comp: Off Server Time: 2026-06-20 18:05:05 UTC
