Re: Trouble with 1gen v6 idle? read on... [Re: Darrell] #1017503 10/22/11 07:18 AM
tdf46 Offline
So I got a salvage throttle body and sure enough that did the trick. I now can control the idle. I still think it is mysterious that nothing I tried could identify a vacuum leak. Oh well.
Darrell....In your case there likely was no vacuum leak. The idle air control passage inside the bottom of your old TB had worn out and was likely letting max air possible through that bypass. I had the same thing with my 89 3.0 and just recently got a wrecking yard TB that solved my problem also, but I have no confidence that it will last.
Has anyone opened a TB of this configuration and thought about designing a work around that would provide adjustable air bypass. This bottom passage could supply the minimum idle air required for a very slow idle, so that one could then adjust the idle to spec using the top side of the TB adjustment screw to speed the idle up ( by backing the screw out)?
The engine may be cold blooded by going that route but at least it would be happy when it warmed up. The drivers and the brakes would be happy also!....:-)
Re: Trouble with 1gen v6 idle? read on... [Re: tdf46] #1017504 10/22/11 04:07 PM
Darrell Offline
Ok that makes sense. I took both of the TB's completely apart to clean and inspect to see if I could locate the problem with the original one. They looked identical. Half of the bottom air passage is controlled by the ICS the other is some sort or water temp controlled spring thing. My guess is that when it's cold the spring contracts and when its at normal operating temp the spring expands and seals off the passage not allowing any air through.
The one idea I had looking at it was to use something to seal the temp controlled thing off permanently. It would fix the high idle problem but it would prevent the engine from reaching normal operating temp as quickly.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5975 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-06-21 22:36:20 UTC
