Remanufactured 2.6L Montero Engine #1018328 01/16/11 12:29 AM
MontyTex Offline OP
I'm at a loss. I have had zero luck finding a reputable source for a remanufactured 2.6L engine for a 1988 montero. Anybody have any suggestions? I don't mind spending good money either.
Re: Remanufactured 2.6L Montero Engine [Re: MontyTex] #1018329 01/16/11 12:38 AM
LandRaider Offline
Best bet is to rebuild it yourself.
I know it's not for everyone, but if you want it done right, you've got to do it yourself. STAY AWAY FROM JASPER ENGINES.
Re: Remanufactured 2.6L Montero Engine [Re: MontyTex] #1018330 01/16/11 01:47 AM
plh Offline
Check with these guys. EMS
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Remanufactured 2.6L Montero Engine [Re: plh] #1018331 01/16/11 01:51 AM
A
airbats801 Offline
you could try engine machine servce also. I'm sure he would do a na engine for ya. Doesnt mitsubishi still have brand new shortblocks? If you were local I would help you build one.
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: Remanufactured 2.6L Montero Engine [Re: airbats801] #1018332 01/16/11 11:46 PM
MontyTex Offline OP
Thanks for the suggestions! Monday I'll be calling EMS.
I'm not opposed to rebuilding it myself but the thought of buying the wrong (or cheap) parts for the engine just worries me. I'd love to just buy the whole package.
Also, if I'm rebuilding an engine I might as well put in a Starion setup, right? Or are these a bit harder to find rebuilt/remanufactured?
What about http://used-auto-engines.com
or Rising Sun Engines?
Re: Remanufactured 2.6L Montero Engine [Re: MontyTex] #1018333 01/17/11 12:38 AM
Almost all engine rebuilders are crap. They do the cheapest job possible with the cheapest parts they can find, and reuse anything they can, even if marginal.
I recommend removing and tearing down the motor yourself, using the on line factory service manual, and find a reputable machine shop to machine the block/head, then buy the correct sized replacement parts (EMS is a good source), then assemble it per the fsm procedures and torques. If you are careful, you will get a superior job that way, without a lot of extra work, and you'll get out quite a bit cheaper.
Re: Remanufactured 2.6L Montero Engine [Re: MontyTex] #1018334 01/17/11 01:28 AM
RyanB Offline
I don't know if you are in the Dallas/Ft. Worth area, but I am having my block and crank machined at Wayne Calvert Precision Motors in Denton.
They specialize in high performance, but they will work on anything - as long as you don't mind waiting, they are really busy. Everyone I asked in this area said they are the best though.
I had them degrease/clean the block, install new pistons on rods, power hone the cylinders, grind the crank, and provide the bearings/rings. I was quoted $450 for everything but initially I just asked for the crank to be polished, so I am sure it went up some.
Mike Smith Machine Shop in Ft. Worth was also highly recommended to me, but I called him and he was swamped and would do the work, but couldn't promise when he could get to it.
I also considered buying a remanufactured from a shop in Arlington, short block was $450 (after core trade) and long block was $850. But I wanted to make sure it was assembled correctly - or if not, there was no one to blame but myself. :-P
Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: Remanufactured 2.6L Montero Engine [Re: MontyTex] #1018335 01/17/11 01:39 AM
Kevin C Offline
EMS ( edit) / Randy is on this board once in a while. He is one of two people that know of that has a torque plate to pre stress the block on a 2.6 motor to keep the bores rounder when boring and honing.
He does good work and knows these engines very well.
Re: Remanufactured 2.6L Montero Engine [Re: Kevin C] #1018336 01/17/11 08:47 AM
A
airbats801 Offline
I thikn you mean EMS kevin?
http://enginemachineservice.com/
You could do a turbo swap, but it's much more time consuming, and unless you already have a starion laying around to grab parts from it can become a real pain in the butt.
Rebuild prices are around the same for both engines.
Re: Remanufactured 2.6L Montero Engine [Re: airbats801] #1018337 01/17/11 11:59 PM
MontyTex Offline OP
Thanks Airbats801,
Sent EMS Kevin an e-mail about an entire rebuild.
I'd love to rebuilt with a starion, but I do not have an old Starion and the one's I've found have all been wrecked or fitted with cheap parts.
I guess I could rebuild the Montero engine and add a turbo later, right?
The only reason I'm considering a turbo is because I'm afraid I won't have enough power to climb steep hills. Are rebuilt montero engines able to handle most uphill (not crazy 75 degree) climbs with 33" tires?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6422 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-06-12 21:36:47 UTC
