Page 6 of 6 1 2 3 4 5 6
Re: exhaust replacement [Re: londart] #1018828 02/23/11 05:00 AM
promodmerc Offline
I'd like to get the header for my 2002. If I do I will have the flange for the converter cut off and a 3 bolt header flange welded on. This way I could have an after market high flow converter welded to an opposing flange so it bolts right up.
Re: exhaust replacement [Re: promodmerc] #1018829 03/16/11 01:21 PM
BAZINGA Offline
I got my Wildcat extractors on! With the Lukey Turbo muffler it has more power at the lower revs.
Sounds good too.
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: exhaust replacement [Re: BAZINGA] #1018830 03/16/11 02:48 PM
4
4runnernomore Offline
G'Day Werd,
Congrats on the setup. I am jealous as it is something I have been wanting to do to mine for a while. the rattly exhaust is driving me nuts!
Did you end up replacing the pipe with larger diameter (2 1/4 inch), mandrel bends and hiflow cat?
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: exhaust replacement [Re: 4runnernomore] #1018831 03/16/11 11:30 PM
BAZINGA Offline
I stayed with stock pipe. It's correct to say that the motor needs back pressure. Not having a cat for some years and then putting one in, the increase in power was substantial. My mechanic said that there is very little difference between the high flow and standard cat, so I went with standard.
I have to put the heat shield back on, it gets mighty warm in the engine bay. As I have no plastic intake up to the air filter box, sucking in that hot air, I have read, decreases performance. Apart from that the main wiring harness comes out of the firewall right beside it. Only problem with putting the heat shield back on is I am going to have to spot weld a couple of bolts onto the top of the extractors. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: exhaust replacement [Re: promodmerc] #1018832 03/16/11 11:37 PM
BAZINGA Offline
Why cut the flange off the extractors? I cringe just to think about doing that. I got a flange made to fit the extractors. With a bit of gasket in between, a couple of slots on the pipe on the opposite end, with a bit of muffler putty and a U bracket, it worked a treat. The stock exhaust pipe fitted inside the 2" pipe nice and snuggly.
Re: exhaust replacement [Re: BAZINGA] #1018833 03/17/11 05:29 AM
Sportege_Panicmech Offline
oh... ok. smile whew smile
Re: exhaust replacement [Re: Sportege_Panicmech] #1018834 03/17/11 02:28 PM
fokion Offline
werd be carefull also with the brake pump
A friend of mine in his sportage with custom header also fried it..
Re: exhaust replacement [Re: fokion] #1018835 03/17/11 02:37 PM
BAZINGA Offline
That won't be a problem, brakes are on the other side.
Re: exhaust replacement [Re: BAZINGA] #1018836 03/17/11 06:47 PM
fokion Offline
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Forgot you are driving on the wrong side!!!!
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6381 MB (Peak: 0.7415 MB) Data Comp: Off Server Time: 2026-06-07 11:37:15 UTC
