welded diff
#1019034
01/23/11 02:10 PM
just making sure i got this right before i go ahead and do it.. follow this post http://www.4x4wire.com/forums/showflat.p...p;vc=1&nt=2up to here : ![[Linked Image]](http://img.techpowerup.org/091022/IMG_5100.jpg) ![[Linked Image]](http://img.techpowerup.org/091022/IMG_5102.jpg) then weld these gears like this (this is a chevy gear) ![[Linked Image]](http://images.ford-trucks.com/articles/2003/4a0d4d6c.gif) reassemble, fill with fluid, now you've got locker? ::EDIT:: ive also seen where they just take all these gears and weld them to the housing : ![[Linked Image]](http://img.techpowerup.org/091022/IMG_5100.jpg) which method would be correct? or stronger? im thinking welding them all to the housing would be pretty much the same thing, and be a lot stronger.
~88 Raider 2.6L 5 speed ~35"x14.5"r15 ~SOA(Spring Over Axle) ~TT(Torsion Twist) ~SBL(Sloped body lift)
Re: welded diff
[Re: LeeForget]
#1019035
01/24/11 04:50 AM
If you do it like that, it'll prob blow up.
You need to weld the spider gears to themselves while they are inside the differential.
Search Lincoln Locker, and you will find many posts on this. I've written out explicit instruction to it before.
Re: welded diff
[Re: LandRaider]
#1019036
01/24/11 05:18 AM
Search Lincoln Locker, and you will find many posts on this. I've written out explicit instruction to it before. If you dont have a welder, cant you just fill the teeth in with JB weld? It cures up pretty darn hard.
Re: welded diff
[Re: LandRaider]
#1019037
01/24/11 05:22 AM
With the pin in, I tacked the gears in front. Then I pulled the pin out and rotated the assembly 90 degrees so I could weld the back side of the gears. This pic just shows the tacks before I did the full weld...I was able to weld the full length between the tack welds: ![[Linked Image]](http://i401.photobucket.com/albums/pp91/nateadam_photos/diff2.jpg) I then rotated it back the way it's supposed to be, but the pin back in, and then finished welding from the front. Sorry, I took this pic a few months ago and didn't realize that it was out of focus. Hopefully it's good enough to get the idea. ![[Linked Image]](http://i401.photobucket.com/albums/pp91/nateadam_photos/diff.jpg)
1989 Mitsubishi Montero SWB 0.0L (3.5L soon?) Auto, Front LSD, Rear SR Locker, Aisin hubs, Safari Snorkel, ARB Front Bumper, Warn M8000, Bushwacker Flares 1984 Mitsubishi Montero 2005 Dodge SRT-4 1970 Plymouth 'Cuda (in pieces) ...and a few others less interesting.
Re: welded diff
[Re: Kevin C]
#1019038
01/24/11 05:28 AM
This is the way I usually do it. It can affect horsepower though... ![[Linked Image]](http://www.outlawperformance.com/uploads/diff-fail.jpg)
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
Re: welded diff
[Re: justice]
#1019039
01/24/11 06:04 AM
Must be tricky to get it into the case like that.
Re: welded diff
[Re: Kevin C]
#1019040
01/24/11 07:14 AM
lol, I'd imagine it's a real bear to setup the gear mesh pattern also
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe 87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: welded diff
[Re: justice]
#1019041
01/24/11 01:13 PM
That should quiet down those noisy gears.
Re: welded diff
[Re: OldColt]
#1019042
01/24/11 08:00 PM
Weld the gears together only, welding to the housing will crack because of the type of casting it is. I plate over the pin and weld the gears together and to the plate.
Re: welded diff
[Re: LandRaider]
#1019043
01/25/11 02:50 AM
Search Lincoln Locker, and you will find many posts on this. I've written out explicit instruction to it before. With the pin in, I tacked the gears in front. Then I pulled the pin out and rotated the assembly 90 degrees so I could weld the back side of the gears. This pic just shows the tacks before I did the full weld...I was able to weld the full length between the tack welds: ![[Linked Image]](http://i401.photobucket.com/albums/pp91/nateadam_photos/diff2.jpg) I then rotated it back the way it's supposed to be, but the pin back in, and then finished welding from the front. Sorry, I took this pic a few months ago and didn't realize that it was out of focus. Hopefully it's good enough to get the idea. Weld the gears together only, welding to the housing will crack because of the type of casting it is. I plate over the pin and weld the gears together and to the plate. Thanks guys. Ill get back to ya after ive welded her up.
