Re: I'm lovin this dynomat stuff [Re: off-roader] #1019114 01/25/11 09:05 PM
KrzyDav Offline
I got some of that stuff at NAPA. It's inexpensive. It come with reflective on one or both. It's hard to cut. The reflective surface is not very abrasion resistant.
I used it on the inside firewall to reflect heat away from my relocated ECU. Don't know it that matters but with that old a computer, and the fact when I modify thing I open pandora's box.
dave h.
Re: I'm lovin this dynomat stuff [Re: zarktheshark] #1019115 01/26/11 04:25 AM
Kevin C Offline
It must have been the weekend for it. I had some left over from when I did my Raider. Its been taking up space for about five years so I put it to use on my Passats floor boards to reduce tire noise when I drive on rough roads.
I drive on RT 26 in the Portland area, a very noisy road. It really did help... Now I need to buy some more.
The Dynamat is a damper material. A thin sheet of elastomeric with an aluminum cover. Just over the wheel opening I used three layers. Further away from the noise source I just used two layers, tapering off to one layer.
It seems to stop the floor from being vibrated by the tire.
When I did the Raider I also did the roof. It does seem to work pretty well and its thin enough to put a stick on headliner over it.
Fun stuff,
Kevin
Re: I'm lovin this dynomat stuff [Re: RECON45] #1019116 01/26/11 05:25 AM
W
w8lon Offline
I looked around on the web and found similar material to what we used in yacht building industry.Looks to be reasonable.soundproofcow.com what I'm looking at is called Quiet Barrier.4 1/2ftx20ft roll $118.45 and probably is not self adhesive.
90 LWB,Treehugger
97 Subaru Legacy L wagon
Re: I'm lovin this dynomat stuff [Re: w8lon] #1019117 01/26/11 04:12 PM
cdl1701 Offline
Here is the stuff that I am planning on installing this summer
Rattle Trap
They make some thinner stuff also called FatMat
88 Montero, 2.6 Black
Re: I'm lovin this dynomat stuff [Re: off-roader] #1019118 01/26/11 05:15 PM
Oyaji_Jon Offline
So is there a decent 'low cost' alternative? Not interested in rhino/hercu-lining anything either.
The Land Cruiser crowd loves this stuff because of its "lower" cost when covering the expanse of an LC interior: http://www.secondskinaudio.com/vibration-mat/damplifier.php
Check out their other products, too. They have some pretty cool stuff.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: I'm lovin this dynomat stuff [Re: Oyaji_Jon] #1019119 01/26/11 06:02 PM
zarktheshark Offline OP
Funny, i ran across those sites last night. Of course, they all say they are better than the other guys, but I wonder how close the actually are. both of those dynamat alternatives are quite a bit cheaper than dynomat.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6187 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-07-10 19:20:02 UTC
