How many quarts for 88 Raider? #1019124 01/24/11 09:56 PM
bar2hunter Offline OP
How many quarts does a stock 2.6 4 cyl in an 88 Raider typically hold?
Re: How many quarts for 88 Raider? [Re: bar2hunter] #1019125 01/24/11 10:44 PM
RyanB Offline
6.1 quarts - according to the FSM. I think you can get away with 6 though. :-P
Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: How many quarts for 88 Raider? [Re: RyanB] #1019126 01/24/11 11:16 PM
Ryan
Hey!...another Texan in the house! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks for input!
Re: How many quarts for 88 Raider? [Re: bar2hunter] #1019127 01/25/11 04:57 AM
It may hold 6 quarts, but I don't think you'll drain that much out. I'd check after the fourth, figuring on a fifth.
Re: How many quarts for 88 Raider? [Re: MontyMcV] #1019128 01/25/11 02:58 PM
Jamez Offline
Just changed mine a week ago, takes the whole 5qt jug and most of another quart.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: How many quarts for 88 Raider? [Re: Jamez] #1019129 01/25/11 10:12 PM
Cool. Guess that means it's been too long since I changed mine- if I can't remember something like that... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: How many quarts for 88 Raider? [Re: MontyMcV] #1019130 01/25/11 10:55 PM
dadrab Offline
Not necessarily...
My turbo engine doesn't seem to take as much oil as the old N/A 2.6 did. I have no idea why. What you describe is about right as I usually buy six quarts and check the stick after adding five only to have to add one or two more ounces. <img src="/forums/images/graemlins/kewl.gif" alt="" />
with awesome audio.
Re: How many quarts for 88 Raider? [Re: Jamez] #1019131 01/26/11 02:24 PM
Thanks!
Re: How many quarts for 88 Raider? [Re: bar2hunter] #1019132 01/27/11 04:37 AM
Kevin C Offline
The manual does call out five qts for the crankcase and 1/2 qt for the filter.
Overfilling can cause problems...
I deepened the sump on mine to hold 2 extra quarts. Sound like a great idea until you drain your oil and forget that your catch pan only hold 5 1/2 qts... That left a mark in the driveway.
Kevin
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6252 MB (Peak: 0.7124 MB) Data Comp: Off Server Time: 2026-11-18 22:38:36 UTC
