Page 3 of 7 1 2 3 4 5 6 7
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019317 01/27/11 11:10 PM
jacumja Offline OP
Also I use "searchallcraigs.com" and browse the local 4x4 club forums daily any ideas where I might should look for them also?
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019318 01/28/11 12:05 AM
4-cyl came with ATs. Some have swapped a later Gen I V6 due to its lock-up TQ converter. (Need a 4-cyl AT bellhousing on the V6.) Search on this and you'll find lots of posts.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: MontyMcV] #1019319 01/28/11 02:20 AM
also try searchtempest.com to search multiple CL cities.
The optimal recipient for a turbo conversion is the a/t, in my opinion. There seems to be an almost perfect match between the a/t comverter stall characteristics and the onset of boost pressure to almost avoid turbo lag altogether. Ditto the use of a 90.5 or later a/t with the lockup converter with the 4cyl bellhousing. Of course, you will have to swap the flywheel of a m/t donor motor to the truck flexplate and crank end adapter, and remove the pilot bearing from the rear crank recess, to use an m/t starquest motor in an a/t truck, but it's a straight bolt on.
Note that in the tech threads stickied at the top is a complete turbo conversion bible started by me with contributions from many that gives very complete instructions and alternate methods and discussions of the best donors (the 88-89 a/t starquests) and the acceptable donors.
I did my first 2.6 turbo conversion years ago with no internet, two factory shop manuals, and an 85 4wd mitsu pickup and an 85 conquest donor. I spent weeks sitting in the driveway with two sets of wiring diagrams and two snarls of unwrapped wiring harnesses and lots of hurled tools. It's LOTS easier now, all figured out, by smarter people than me.
Your strategy of finding a 4cyl truck and saving the pennies until you find a donor, then rebuilding the donor motor, all while still driving the recipient is very sound and leaves the minimal downtime.
I've seen non running donors for as little as $500 asking, which is what I paid for mine years ago. I've recently seen several with only minor problems in the 1000-2000 range asking price. Get a whole donor vehicle, it's lots easier than trying to source all the bits.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: fasteddy] #1019320 01/28/11 05:42 AM
Other things to consider with a V6 SWB are the number of chassis unique things that are hard to find, particularly fuel tanks and interior bits. The rear suspension of the V6 SWB is the same as the 4door, coil springs and trailing arms. The 4-cyl is leaf springs.
Being that more 4-cyl models were built than V6 SWBs, you have a statistically higher probability of finding a 'nice' 4cyl to start with, and parts are more common.
Regarding the steering column, no differences for the Gen I trucks I've parted out. The steering wheel on the pre-88 4-cyl is smaller in diameter. I haven't figured that out, but perhaps it has something to do with the faster ratio steering box in later Gen Is? Maybe the difference in the steering wheel diameter gives the same amount of steering effort measured on the outside of the steering wheel?? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: rxinhed] #1019321 01/28/11 06:34 AM
jacumja Offline OP
I drove up to Ocean Isle last weekend in the snow to test drive a V6 mt and when I got there it cranked one time and cut right off. The later explanation I heard from the owner after I got all the way home was. " It was out of gas"? I really wished I could have seen what the 6 drove like. I really think it would be adequate for what I need and I'm sure I can find ways to pep it up.
Not making excuses but I simply don't have access to the facilities and tools that you guys have. Monday through Friday I'm at a condo at the Beach where the retirees/Hoa bitches if I fart up wind in the parking lot. They'd shart themselves if I had motor swap party out there.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019322 01/28/11 11:14 AM
Bernoulli Offline
I'm not a technically gifted as a lot of responders here. I've owned 5 SWBs (have two now)and one LWB (diesel). I've had 3 of the 4-bangers. My experience is that the V-6 is worth waiting for. More power, better mileage and a larger gas tank. I've found it to be more reliable. As others have mentioned here, it's easier to upgrade.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: Bernoulli] #1019323 01/28/11 01:43 PM
Charlie Belew Offline
I'm not a technically gifted as a lot of responders here...
Hey Bernie, did you get flooded with all the rain in Brisbane?
None
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: Charlie Belew] #1019324 01/28/11 02:59 PM
jacumja Offline OP
Why is the Black exterior with tan interior so hard to find. I've seen a few and really like the look but they're impossible. I find a lot of red and grey.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019325 01/28/11 05:53 PM
highmtndesert Offline
Too bad your so far away. I would make you a good deal.
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: highmtndesert] #1019326 01/28/11 08:11 PM
DRaider90 Offline
Let me put it this way I am around 6'7" tall and I have driven Raiders/Monteros since before I was of legal age to drive with no issues. This is with the stock steering wheel of course. At 6'4" you should have no issues.
I think the 4 banger gets a bad reputation for power from a lot of these trucks being worn out, and still having the stock Mikuni Carburetor. You put a Weber on a 2.6 and it makes a difference. But it all boils down to the size of tires you want to put on it. 31"s or 32"s are the MAX if you want to keep a good bit of power/mpg. I ran 21mpg city/highway mixed driving with a top speed of 90mph (down hill of course) with 31x10.5s. Now with 34x9.5s my top speed is about 80-85mph going down hill, and it takes a good while to get the tires spinning that fast. And I am looking at 15-16mpg mixed driving.
If I had free time and gas money to visit the beach (a little over 3 hours trip for me), I would drive down for a day and let you drive it so you could make your own decision about power and the 2.6.
Just keep in mind in the long run you are buying a metal tank powered by a 2.6 4 banger, or a 3.0 V6. These trucks can hit and drive over fire hydrants and keep going (guy ran me off the road long story). You can hit (or smash into in my case) a deer with one and maybe at most replace a grill/bumper. So either way its not going to be a speed demon, but it will take you just about anywhere you want to go. If/when you pick one up, you need to make a trip out to Uwharrie with the rest of the NC/SC guys. <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.013s) Memory: 0.6466 MB (Peak: 0.7729 MB) Data Comp: Off Server Time: 2026-11-20 02:25:35 UTC
