Page 7 of 7 1 2 3 4 5 6 7
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019357 02/08/11 02:32 AM
... expeditionportal.com every night.
Are you Zukrider on the ExPo?
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: off-roader] #1019358 02/08/11 06:07 AM
jacumja Offline OP
no im not I use the same handle
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: jacumja] #1019359 02/08/11 05:01 PM
seattleraiders Offline
HEHE, yep, that sounds about right. I have a SWB 89 raider with all the power, v6,cruise, blah blah....but it needs a right front corner. Thats where the red 88 came in for some body parts and misc interior pieces. Now i have an 85 white one that will take the rest of the cool pieces, and is going to get a 2.3 liter diesel engine and perhaps a right hand drive conversion. Ill have to get one more to take all the other gas leftovers and make back into an art car. I wonder if you can remove the transfer case, pull the front drive line and make a two wheel drive dragster out of one of these?
Check out nwmitsubishidiesel.com for fun....
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: seattleraiders] #1019360 02/09/11 02:34 AM
You can do a turbo swap and put the tranny from the StarQuest behind it.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: seattleraiders] #1019361 02/09/11 04:53 AM
KrzyDav Offline
If you want to pull the front axles out, you can get the dummy plugs out of a 2wd Montero sport to pound into your spindles.
dave h.
Re: Advice Needed Regarding Dodge Raider/Mitsubishi Montero 2 door [Re: KrzyDav] #1019362 02/09/11 04:56 AM
And weld in a carrier for the starquest IRS, too, with the truck 4.625 gears swapped in place of the 3.54's, and you get the electroadjustable shocks and the tootsie roll tires, too...
PHP: 7.4.33 Page Time: 0.023s Queries: 16 (0.018s) Memory: 0.6178 MB (Peak: 0.7040 MB) Data Comp: Off Server Time: 2026-11-20 03:44:56 UTC
