Weber conversion for 2.6l
#1019991
02/07/11 05:08 AM
I am replacing my "Mikuni of unknown origin" (not for a 1984 Montero for sure), and installing a Weber 32/36 conversion. I read through all the old posts and have also purchased an Airtex inline pump and a Holley regulator to delete my mechanical fuel pump.
Is there anything else I need other than plugging the unused vacuum lines and wiring in the new pump?
I assume it is okay to leave the mechanical fuel pump disconnected without removing it and fabricating a plate?
Thank you for any input, Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: Weber conversion for 2.6l
[Re: RyanB]
#1019992
02/07/11 05:35 AM
you should put a second fuel filter between the tank and the elec fuel pump. you should also plug the water port in the intake manifold that will sit under your adapter plate. most tap the hole and put a bolt that will not stick up. it was there to help warm up the stock carb. You will also have to plug some other manifold coolant lines that used to connect to the carb. As for the mech pump, I left mine on, but removed the cam following rod from the pump so that it would not cause any additional drag. I'm not sure how you are powering your fuel pump, but I ended up running an oil pressure solenoid so the pump shuts off if running less than 2psi. You should also run a fuse on the pwr to the pump. since elect pumps are sometimes noisy, I bought a quiet pack from napa. it is a set of 3 rubber issolaters that have bolts on both ends which i attached to my frame.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
[Re: zarktheshark]
#1019993
02/08/11 01:41 AM
Thanks for the heads up on the coolant plug, I am waiting on shipping so I will get that taken care of now.
I was just planning on running a relay triggered by the coil for the electric pump. I am not sure how I would go about wiring in an oil solenoid, although I think it is a great idea.
What all is required to add this? Just adding in an oil pressure solenoid and running the signal wire through it to the relay?
Thanks for the info so far, I knew I would overlook something.
Ryan
[Re: RyanB]
#1019994
02/08/11 05:54 PM
the oil solenoid I bought from napa(i think) LINK . basically, you pull out the oil sending unit from the block, put in a T fitting, put the sending unit in one side the solenoid in the other. You then have 3 wires to hook up. one from the starter system, one switched pwr and one that goes to the pump.
[Re: zarktheshark]
#1019995
02/08/11 07:42 PM
Make sure you have a solid ground for the pump. Using the mounting bolt may or may not work well so either check it with a meter beforehand or just run a ground wire with the power.
'87 Raider w/rebuilt 2.6 Weber 32/36
[Re: Jamez]
#1019996
02/09/11 01:45 AM
Thanks again. I found a Holley safety switch that my local auto parts can get which is very similar to the one you found. I just have to locate a T which shouldn't be too hard and I will be good to go.
Now I won't have to watch the oil pressure gauge quite so closely.
Thanks for the tip on the ground as well, I will run a wire to the firewall ground probably.
Ryan
[Re: RyanB]
#1019997
02/09/11 02:02 AM
Why are people useing electric instead of the stock pump when doing the weber conversion.
[Re: Smalltimedodge]
#1019998
02/09/11 02:11 AM
Why are people useing electric instead of the stock pump when doing the weber conversion. No idea...I'm using a Weber 32/36 with the stock fuel pump...I know you need an upgraded fuel pump with the turbo conversion, and possibly if you run the larger Weber 2-barrel (38?). But I was under the impression that no fuel pump upgrade was needed with the Weber conversion...
 1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012) Southeast VA, USA
[Re: socal1200r]
#1019999
02/09/11 02:36 AM
correct, you don't have to upgrade. I just wanted too
[Re: socal1200r]
#1020000
02/16/11 04:51 AM
Why are people useing electric instead of the stock pump when doing the weber conversion. No idea...I'm using a Weber 32/36 with the stock fuel pump... Same here with the Weber 38 - although I also added a Holly fuel pressure regulator between the pump and new carb.
The Redneck Special: 88 Ram 50 2WD XCab with 167K on the original 2.6L, 5-Sp, Weber 38DGS, Crane HI-6 with timing adjust, 4-for-$100 tires, Generac 4000EXL 4KW AC generator, Hampton Bay 12KBTU window air conditioner sticking through a hole hacked in the back of the cab...All it needs now is a gun rack...
