Re: A Different Sort of Diagnosis Needed [Re: Kevin C] #1021221 02/21/11 03:13 AM
FrankR Offline OP
I think the gauge leaked internally. Look at the picture of the blown gauge and notice the corrosion on the "0" peg.
Frank
Re: A Different Sort of Diagnosis Needed [Re: rxinhed] #1021222 02/21/11 03:58 AM
87Montero Offline
I thought this was not about Mitsu-porn. Darn!
I groped that engine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: A Different Sort of Diagnosis Needed [Re: 87Montero] #1021223 02/21/11 04:13 AM
Duly noted. Wondered about that some. Is there any chance the gauge was interfering with the action of the fpr? Could you identify the various hoses on the fpr? I count 3? In the photo, Rside, Lside, and bottom...
Have you demo'ed the gauge yer to investigate failure mode?
Re: A Different Sort of Diagnosis Needed [Re: fasteddy] #1021224 02/21/11 12:33 PM
FrankR Offline OP
I don't see how the gauge could interfere with the pressure regulator unless it leaked to the outside (remember the occasional fuel odor with no fuel leak found).
There are 3 fuel lines connected to the regulator. The fuel rail is split-feed/split outlet, with each rail's outlet connected to an inlet port on the side of the regulator that is connected to a common chamber. The 3rd fuel line (bottom) is the return.
I check the regulator fairly often by observing the gauge at idle whenever I change the oil. I checked it on 2 separate occasions under load on the dyno and it was always smooth and steady.
Frank
Re: A Different Sort of Diagnosis Needed [Re: FrankR] #1021225 02/21/11 02:40 PM
...by observing the gauge at idle whenever I change the oil...
You're not running the engine with no oil, right? That'd be a problem. <img src="/forums/images/graemlins/wink.gif" alt="" />
How about depth of the gauge sensor in to the fuel passage?
Re: A Different Sort of Diagnosis Needed [Re: rxinhed] #1021226 02/21/11 06:12 PM
FrankR Offline OP
No, there's plenty of room.
Frank
Re: A Different Sort of Diagnosis Needed [Re: FrankR] #1021227 02/23/11 10:08 PM
joestruck Offline
YOu inadvertently hit/adjusted the 710 cap?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6261 MB (Peak: 0.7011 MB) Data Comp: Off Server Time: 2026-07-13 14:30:42 UTC
