Front LSD
#1021269
02/21/11 10:49 PM
Did they make a front LSD in an 87? If not what would work in it? Thanks Mike
Re: Front LSD
[Re: 87Raider]
#1021270
02/22/11 12:09 AM
No LSD or traction aid of any kind was offered from the factory, in any year, Montero or Raider. Others have swapped in an LSD from a Starion or Conquest. It has been discussed quite a bit. Several people have done very detailed write-ups on it. Do a bit of searching and you should turn up a good amount of reading material that'll point you in the right direction. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" /> EDIT: Here's the write up that I was referring too.
Re: Front LSD
[Re: hazy_daze]
#1021271
02/22/11 03:25 PM
Isnt the 87 Monty the oddball trying to figure out which starion LSD to use?
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: Front LSD
[Re: willwinchforfood]
#1021272
02/22/11 04:11 PM
Given how the swb shudders in a tight turn with a rear lsd, I'd want to reduce the preload on the lsd in the front, maybe take out some plates/friction discs, or add more friction modifier to make it more slippery. Search under KevinC and front lsd for a writeup he did several years ago.
Re: Front LSD
[Re: fasteddy]
#1021273
02/22/11 09:49 PM
Im waiting on some parts for my front Tsi LSD swap (Which I have) with a little change of direction, But If it all works out I will let you know.. As for the comment above an Odd ball can be a good thing <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Like Turbo monteros pssst
2003 limited 20 year anniversary 96 SR 87 Montero SWB=Turbo diesel 4BT T19 4sd with 205 transfer case
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6048 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-06-17 17:56:21 UTCValid HTML 5 and Valid CSS
