2.6 auto flex plate? #1021391 02/22/11 06:25 PM
powerRam50 Offline OP
anyone know if there is any company selling new flaxplates for the 2.6 auto's in the montys?brothers monty is chewing thru starters and might of mangled some teeth on the ring gear.i would prefer to try and find new before looking at junk yards.
Re: 2.6 auto flex plate? [Re: powerRam50] #1021392 02/22/11 07:04 PM
87monty Offline
I will let you in on a little secret, When I did my turbo swap I found out the flex plate from the starion turbo motor works all you need to do is remove the crank spacer on the montero motor, line up the holes on the montero flex plate so that there is enough meat around all 5 holes (because the starion has 4 holes) then mark them and drill.
The starion flex plate is the same in size just off-set do to no spacer in the starion set up. <img src="/forums/images/graemlins/smile.gif" alt="" />
So get one of them there easyer to find...
Mine is a DD and have had no problems at all oh and its built alot better as well..
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 2.6 auto flex plate? [Re: 87monty] #1021393 02/22/11 10:33 PM
that would be perfect if it was my truck but it is my bro's.i dont even want to pull the tranny but i am tired of looking at it and my wife wants her d-50(he is borrowing it).
Re: 2.6 auto flex plate? [Re: powerRam50] #1021394 02/22/11 11:02 PM
87monty Offline
Well them flex plates are hard to find and expensive to boot. Bummer
96 SR
Re: 2.6 auto flex plate? [Re: 87monty] #1021395 02/22/11 11:44 PM
dougl3nc Offline
I have a brand new one with cosmoline still on it. Ordered it a year or so ago from Mitsubishiparts.com for $240+shipping or so IIRC. I'll take $225 shipped for it.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: 2.6 auto flex plate? [Re: dougl3nc] #1021396 02/23/11 12:22 AM
doug i dont think he will have the money till this summer but if you still have it then i will probably pm you when he gets ready to buy.
Re: 2.6 auto flex plate? [Re: powerRam50] #1021397 02/23/11 12:30 AM
mxmikie Offline
i have some used ones for $75.00
Re: 2.6 auto flex plate? [Re: mxmikie] #1021398 02/23/11 02:21 AM
A
airbats801 Offline
I sold mine for 15 or 20 awhile back. I cant believe they are worth that much, just find a fella who hates automatics and swapped his out and you can probably get one cheap smile
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: 2.6 auto flex plate? [Re: dougl3nc] #1021399 01/13/12 03:13 PM
A
auxarcsjl88 Offline
Do you still have the flexplate? Mine is just like the pic you posted last year/
Re: 2.6 auto flex plate? [Re: auxarcsjl88] #1021400 01/13/12 05:19 PM
mxmikie Offline
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6372 MB (Peak: 0.7608 MB) Data Comp: Off Server Time: 2026-06-21 09:49:25 UTC
