Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: hadtomer] #1021564 04/27/11 01:32 AM
BAZINGA Offline OP
is that manifold in the picture for the sporty??
Sure is! <img src="/forums/images/graemlins/cheers.gif" alt="" />
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021565 04/27/11 06:25 AM
hadtomer Offline
im not jealous. im not jealous. im not jealous (if i will keep chanting maybe it will help). does it make any difference? my sporty is really underpowered
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: BAZINGA] #1021566 04/27/11 02:14 PM
bombardj1 Offline
some of you say your radiator's only last a few years, what type of water are you mixing with the coolant? I hope it's not tap water
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: RADIATOR ON '99 WITH AUTO TRANSMISSION [Re: bombardj1] #1021567 04/29/11 07:36 PM
logansportage Offline
That was what I did. I was actually out on a trail when I overheated and all I had was drinking water we had with us. When I got back I forgot to flush the system and replace it with correct fluid. ThatÆs why my radiator is so plugged up.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6070 MB (Peak: 0.6624 MB) Data Comp: Off Server Time: 2026-07-09 15:53:59 UTC
