Re: shocks?
[Re: grass13]
#1022065
03/05/11 04:26 PM
After I replaced Frt/Rr shocks on the Montero and Frt/Rr struts on my Camry I've decided NOT to buy KYB again. Only the rear Montero shocks were banded (seems a common complaint) while the fronts were a struggle to get compressed enough to install - and these were the Gas-a-Just, not the higher pressure Monomax. The Camry's were ordered with installation accessories that proved of such poor quality that I had to use some of the original mount parts. I've learned and agree that KYB stands for "Keep Your Bilteins".
Re: shocks?
[Re: pcc]
#1022066
03/06/11 08:05 PM
Per KYB, the only reason they band some shocks is to make them fit in the box. The front shocks for a Montero aren't very long even when they're extended, therefore, no band. Not so for the rears, which are quite long when extended.
I weigh 160-odd pounds on a good day, and I can compress the shocks for the front. It's keeping them compressed that's kind of frustrating. Just work smarter, not harder.
Sorry you had a bad experience with KYB. I myself have not.
Re: shocks?
[Re: JohnnyBfromPeoria]
#1022067
03/06/11 08:33 PM
Just work smarter, not harder. Used a coat hanger (and help from my wife) to hold compression and got it done. How much would it have cost KYB to include a nylon band. On the Camry the included strut retainer nuts were of such poor quality they stripped with correct torque and I had to re-use originals. As well the retainer flats were incorrectly machined too large for the flats on the strut shaft and I could not torque properly as the shaft would slip in the retainer. Emails to KYB were ignored. Why couldn't KYB work smarter so I wouldn't have to work harder?
Re: shocks?
#1022068
03/06/11 09:51 PM
Johnny B posses' super human strength...alowing him to compress the KYB's. Maybe KYB should put a disclaimer on the box...Something to the effect of.."dont buy these if you are too much of a wuss to compress these shocks" <img src="/forums/images/graemlins/lol.gif" alt="" /> I installed a set of Monomax's on my buddy's 95 LS took a little bit of effort to get those pushed together, but the end result was good.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
Re: shocks?
[Re: justice]
#1022069
03/06/11 10:17 PM
I agree that getting them in can be a PITA... That part doesn't worry me too much.
What I don line is the valving. Aftermarket gas shocks like Monroe's are too soft and dont hold up. While my KYB's in my opinion are too hard.
Not sure if Bilstein has a set for my 87 4 cyl or not.
I used to run Rancho 9000's. I got a decent ride on the right setting.
Might be time for a change.
Re: shocks?
[Re: Kevin C]
#1022070
03/07/11 03:20 AM
I used to run the adjustable Rancho 9000's on my my 85 Mitsubishi pickup and I loved them because I could set them to firm when carrying heavy loads and then adjust them to the soft setting when in offroad situations.
I have since switched to some very high end Bilstiens and while they are nice shocks, I prefer the Rancho's because of there different settings.
Spence 1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: shocks?
[Re: spencevans]
#1022071
03/08/11 06:48 PM
I agree on the Monroe's. I put the shocks they offer for my 91 and found them to really weak. Blew the rear out in one wood cutting season and the front would bounce alot when I was pulling the trailer (of course I go faster then I should off-road with the trailer) <img src="/forums/images/graemlins/lol.gif" alt="" /> I found load adjusting monroe's that fit for the front and RV shocks for the rear. Better than before. Going with load adjusting for the rear once I get the coil spacers.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: shocks?
[Re: heathdogg]
#1022072
03/08/11 06:55 PM
Heathdog,
Have you tried the KYB or other monotube designed shock for your application?
Re: shocks?
[Re: off-roader]
#1022073
03/08/11 09:56 PM
Not yet. I'm cheap and I can charge the Monroe's to my account at NAPA. My white truck is my work truck so I like it stiff (huhuhuh). I got a black one that will be my nice one so I may go with something else for that one.
Re: shocks?
[Re: heathdogg]
#1022074
03/08/11 11:45 PM
Yeah, I can fully appreciate that. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cyclops.gif" alt="" />
