Re: Exhaust smoking
[Re: justice]
#1022831
03/15/11 01:51 AM
I think vss's too. The extended idle plus a cloud of smoke on start off is a good diagnostic. Ditto the improved guides. The oil smell should be almost identical to what you smell when you drop oil on a hot exh mani. The gassy smell makes it possible you have a leaky injector washing the oil off the cylinder walls, too. Is the smoke bluish tinted? Is there marked oil consumption. I'm still worried about the water loss...
Re: Exhaust smoking
[Re: fasteddy]
#1022832
03/15/11 02:08 AM
Up until recently it wasn't smoking at all. I haven't driven it much over the past couple of weeks, but before that once it was warmed up... no smoke. No marked oil consumption. There may be a slight] bluish tint to the smoke, but it's hard for this novice to tell...
Eric W.
Re: Exhaust smoking
[Re: 89IsMine]
#1022833
03/15/11 02:11 AM
Get the motor good and hot, and take the dipstick out and let a drop fall on the exh. mani and smell that, then compare to the tailpipe smell. The bluish tint will be slight, a gray-blue tint on whitish smoke. The smell is quite distinctive.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6042 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-05-29 22:31:39 UTCValid HTML 5 and Valid CSS
