Page 2 of 3 1 2 3
Re: Can't get snap ring on cv half shaft [Re: Darrell] #1022990 03/17/11 05:49 AM
Btw, be sure to read the FAQ thread at the top of the forum. You'd already know about the downloadable manuals if you had. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Can't get snap ring on cv half shaft [Re: off-roader] #1022991 03/17/11 08:26 AM
haztoys Offline
Is the wheel spindle hagging down ?...If so ...Try jacking the truck up from the a-arm ...Not the frame ...Try installing the ring with the truck on the ground with the tire on ...Try driving it some in 4x4 with no hubs installed ...Just up and down the street ...
Re: Can't get snap ring on cv half shaft [Re: haztoys] #1022992 03/17/11 09:08 AM
4ePikanini Offline
this may help
http://www.4x4wire.com/forums/showthreaded.php?Number=1198179
this snap ring doesn't need to come out
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Can't get snap ring on cv half shaft [Re: 4ePikanini] #1022993 03/17/11 12:29 PM
Tag Offline
There any chance the ring/washer on the back of the inner bearing is on backwards? It has a depression on one side but not the other.
It can be seen in this picture. It is the gold/brass colored ring pushed up against the cv.
http://img641.imageshack.us/img641/4852/1010293k.jpg
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Can't get snap ring on cv half shaft [Re: Tag] #1022994 03/17/11 12:38 PM
Tag Offline
Do you have your upper balljoint connected?
Re: Can't get snap ring on cv half shaft [Re: 4ePikanini] #1022995 03/17/11 03:29 PM
Darrell Offline OP
this may help
Sorry for the confusion. <img src="/forums/images/graemlins/confused.gif" alt="" /> My bad. The snap ring that I am having trouble with is on the right end in this photo:
Re: Can't get snap ring on cv half shaft [Re: Darrell] #1022996 03/17/11 03:34 PM
RECON45 Offline
I have never had an issue with that one. if you have a large pair of slip joint (channel lock) pliers line it up and let leverage do the rest. I will say there is the potential to spring off, but it should go on easily.
Re: Can't get snap ring on cv half shaft [Re: haztoys] #1022997 03/17/11 03:41 PM
Darrell Offline OP
The jack stand is under the a-arm so it is fairly horizontal.
I never thought of driving it. Thanks for the idea I will if I can't get anything else figured out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Can't get snap ring on cv half shaft [Re: RECON45] #1022998 03/17/11 03:43 PM
Darrell Offline OP
Thanks for the feedback. I must have a issue somewhere cause I basically did that and it doesn't find the groove.
Re: Can't get snap ring on cv half shaft [Re: Tag] #1022999 03/17/11 03:47 PM
Darrell Offline OP
That is a great observation. <img src="/forums/images/graemlins/kewl.gif" alt="" /> That is the first thing I am going to look for. I remember trying to remember which way it was supposed to go. The crazy thing is that ring is not in any exploded view. The photos here are awesome.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6414 MB (Peak: 0.7505 MB) Data Comp: Off Server Time: 2026-06-09 23:19:03 UTC
