Sway bar availability #1023447 03/20/11 08:31 AM
Mikewarme Offline OP
I own 2 1st gen 4x4 trucks 1 83 and 1 85 both diesel . I need a new sway bar. Part # MB109677 shows compatible with all 4x4's 83-94 on trucks and Montero from 91-94. Any ideas for aftermarket sources?? I did find a aftermarket bar for the 2wd truck but not the 4wd <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Sway bar availability [Re: Mikewarme] #1023448 03/20/11 09:13 AM
StockRaider Offline
Your talking about the sway bar? or just the links? For the links, I spent $15 for a set of them from advance in the little aftermarket section they have.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Sway bar availability [Re: StockRaider] #1023449 03/20/11 03:25 PM
I normally get everything from the dealer. I need the whole bar and its Obsolete from Mitsubishi. Mine has a bow in it and the aftermarket ones are thicker
Re: Sway bar availability [Re: Mikewarme] #1023450 03/20/11 06:58 PM
Happy Birthday hazy_daze Offline
What's a swaybar?
Re: Sway bar availability [Re: hazy_daze] #1023451 03/20/11 07:48 PM
Take the bent one to a truck spring shop and get them to anneal it and straighten it and retemper the metal.
Re: Sway bar availability [Re: fasteddy] #1023452 03/20/11 08:45 PM
ryany Offline
Or find one in a wrecking yard...
95 Montero SR
Re: Sway bar availability [Re: ryany] #1023453 03/21/11 01:01 AM
I have a few sway bars, one from an 86 Montero, another from a 90 4-door. You're welcome to try them out.
Re: Sway bar availability [Re: hazy_daze] #1023454 03/21/11 05:35 AM
Angelo Offline
What's a swaybar?
<img src="/forums/images/graemlins/confused.gif" alt="" /> I've never heard of these either. Mine are both missing <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Sway bar availability [Re: Angelo] #1023455 03/21/11 03:57 PM
They are what keeps you from pegging the inclinometer on a freeway entrance ramp spiral and lifting the inside front wheel off the ground at the same time...
Re: Sway bar availability [Re: fasteddy] #1023456 03/22/11 04:09 PM
sparkem Offline
Angelo's truck looks like it is going to fall over just turning a corner.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7445 MB) Data Comp: Off Server Time: 2026-06-23 15:57:09 UTC
