Page 2 of 3 1 2 3
Re: Exhaust flamethrower help [Re: off-roader] #1023595 03/24/11 03:56 PM
Kits mean you lose the "I dood it" factor. Big Glen Murphy and I could have bought a cannon, but we made one instead, and fired it every 4th of July. Big Glen even built a shot tower out of an old windmill. It was a real bugger hauling the molten lead crucible to the top...
See, we could have bought M-80's and Cherry Bombs instead...
Re: Exhaust flamethrower help [Re: fasteddy] #1023596 03/24/11 04:21 PM
This is true if you know what you're doing especially when it comes to playing with fire or in your case explosives. It sounds like he doesn't & I don't want to see him on the evening news or worse yet, as a darwin award nominee.
Re: Exhaust flamethrower help [Re: off-roader] #1023597 03/24/11 04:45 PM
Exhaust systems are pretty robust; I'm going to guess he'll be "relatively" safe.
Cherry bombs and M-80's aren't as fun as Silver Salutes, to me. (That's basically an M-80 with a rocket to get it to the desired place in the sky or wherever before it blows).
Re: Exhaust flamethrower help [Re: JohnnyBfromPeoria] #1023598 03/24/11 07:42 PM
0778drz110 Offline OP
Those kits don't have any propane injection. Just a $15 coil, $5 relay, $5 switch, and $10 of wires. For $89.99.
Re: Exhaust flamethrower help [Re: 0778drz110] #1023599 03/24/11 08:09 PM
Perhaps but perhaps by using that kit you'd have flames already... <img src="/forums/images/graemlins/lol.gif" alt="" />
Just sayin. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Exhaust flamethrower help [Re: off-roader] #1023600 03/25/11 03:57 AM
Uhh, not seeing how that would be so? I already have spark and gas, I just need to figure out air. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Exhaust flamethrower help [Re: 0778drz110] #1023601 03/26/11 01:50 AM
Approach it from the other direction. Make a way to adjust the propane to the available air quantity, say with some kind of metering valve, with a fine adjustment capability. Easier than making different size holes in the pipe to ingest varying amounts of air.
I might try some way of dropping the pressure in the exh pipe, like an increase in pipe diameter, with the air intake holes just downstream from the change point. Tapered might be better than a sudden transition, but I'm guessing.
Re: Exhaust flamethrower help [Re: fasteddy] #1023602 03/26/11 04:14 AM
That is what my friend said. The change in pressure would pull air in rather than push out.
Re: Exhaust flamethrower help [Re: 0778drz110] #1023603 03/26/11 06:18 PM
Yes...
Re: Exhaust flamethrower help [Re: fasteddy] #1023604 03/27/11 05:51 AM
4x4Wire Offline
Yes...
"If you can't be a good influence, don't worry, you can still be a horrid example."
Yes it is a good influence...
or Yes it is a horrid example??? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6438 MB (Peak: 0.7536 MB) Data Comp: Off Server Time: 2026-06-22 13:09:32 UTC
