Page 18 of 150 1 2 … 16 17 18 19 20 … 149 150
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023838 06/13/11 04:32 PM
TOASTY Offline OP
I used a 231 from an AX-15 (manual), if you get a deal on an Auto t-case you'll need a clocking ring or someone will be hacking the input shaft down. What you are looking for is a NV241 RocktTrac with a short input shaft.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023839 06/13/11 06:54 PM
Lloyd Swartz Offline
So I need to get the manual Rocktrac for the short shaft then?
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023840 06/13/11 11:04 PM
lordtrunks Offline
both auto and manual roc tracs are 23 spline short input the difference(according to another jeep forum) is the yoke/balancer on the manual are bigger thats what i had lloyd order. gotta get them mall-tero Sr Rubicon badges now lloyd <img src="/forums/images/graemlins/cyclops.gif" alt="" />
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Wrench fest for Lloyd [Re: lordtrunks] #1023841 06/13/11 11:23 PM
Does this mean I get a Trail Rated badge as well? <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023842 06/14/11 05:03 PM
Oky doky, so the manual one is the 241 but not a 4:1 unit, and the automatic one might be it but has a burnt plug....
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023843 06/14/11 05:21 PM
I sent out a request...lets see what that brings in. I think one can be had for 850.00.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023844 06/14/11 06:48 PM
TOASTY Offline OP
Parts recon went down the drain today, lifters alone were $875! Now i remember why i didn't do them when i had the dealer refresh the 1994.
Gasket kit was $275 so with our $300 it might be best to go with the minimum re seal the rear of the engine and probably the valve stems and call it good. New heads are $275 each plus core so i say we run these heads untill they need to be replaced.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023845 06/14/11 06:51 PM
TOASTY Offline OP
HEADS
Lloyd, here's the link to re maned heads for you to check out for future head job.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023846 06/15/11 01:12 AM
I think updated lifters are a luxery right now, I hope I dont live to regret it. But living off un-employment.....Atleast everything else will be fresh.
No t/case yet. The little bastards are illusive. Everyone advertises a 241...but dont say that is 2:72 of course. Since we have a little time I am going to shop for a few days for bargains. 850.00 may be the floor though...
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023847 06/15/11 03:17 AM
I'd place engine priorities at new valve guide seals, external seals and the front end. Never mind some noisy lifters.
As to the transfer case, can't you do that any time? Let's get this thing to 90% and get you on the trails.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.018s) Memory: 0.6570 MB (Peak: 0.7611 MB) Data Comp: Off Server Time: 2026-11-03 13:37:31 UTC
