Page 28 of 150 1 2 … 26 27 28 29 30 … 149 150
Re: Wrench fest for Lloyd [Re: TOASTY] #1023938 07/13/11 10:02 PM
TOASTY Offline OP
Lloyd, The bolts for your flexplate and torque converter are ordered (the flexplate bolts are in actually just waiting on the converter bolts) and today i'm getting the steel for the bumper top plates (i sent you a picture text of the template). I won't have enough money for the bumper hoops but we can worry about that later because i need to have a shop bend them up for me because i don't have a bender. I'll need some measurements for your winch though so i don't put the gussets in the way of the bolt holes. I'm still working on the front frame chop in my head and where is the best location for everything for maximum approach and strength. Because of the body lift i'm worried about the leverage the winch will have over the frame but i'll play with a few different ideas before i do any real cutting.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023939 07/14/11 12:26 AM
Lloyd Swartz Offline
The picture was very hard to see. My screen is just too small. In September I will be getting my first Smart Phone, The Commando.(Military Spec of course)Sounds like a little cash is needed, for junk yard stuff as well. PM me on that. Winch mount on page 5 below.
http://malykh.com/temp/2009-12-30/T-Max%20Outback.pdf
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023940 07/14/11 06:29 AM
Canyonero Offline
Hey, Lloyd. Just out of curiosity I was going to check out the winch. Not sure if it's just me, but the link times out, even trying to use the home page.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023941 07/14/11 07:36 AM
TOASTY Offline OP
Kevin should also be calling you, i guess the valve stem seals we had are a mystery seal and only 8 anyways (must be for 2.6). So you two can go over parts needed like gaskets and whatever.
I'll get as far as i can with what i've got and let you know what we need for steel. i haven't been out to look for 4.90's and hubs for a couple weeks so once i locate something i'll give you a call.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023942 07/14/11 03:34 PM
The web page comes up fine. Its likely you missed one of the 4 PDF updates/ day in the last few weeks <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Otherwise it could be IE9 which seems to be updating automatically and causing a lot of trouble, like 8 did.
Just have Kevin call me and I will figure out a way to get him a few dollars.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023943 07/17/11 04:23 AM
TOASTY Offline OP
Remember that it will be mounted higher on your truck Lloyd with the frame mod, This is my first attempt at a winch mount tube bumper so if there is anything you don't like let me know, nothing is permanent yet. I have some trimming and a center plate to make still. [Linked Image] [Linked Image] [Linked Image]
Re: Wrench fest for Lloyd [Re: TOASTY] #1023944 07/17/11 03:40 PM
You know that does not look half bad. I like those flat side plates, since I am such a chicken and love people getting on my truck when I get tippy <img src="/forums/images/graemlins/lol.gif" alt="" /> Very practical appearing, and a strong gusset for the ends.
A short return toward the tire to protect the fender corners would be a nice add.
Re: Wrench fest for Lloyd [Re: Lloyd Swartz] #1023945 07/17/11 06:08 PM
TOASTY Offline OP
Yeah, I?d like it to wrap around as well, i think it?ll look way cleaner. As for the top mount winch I'm still on the fence about that with the amount of lift we're going to have on the frame. I'll call and talk it over with you later today.
Re: Wrench fest for Lloyd [Re: TOASTY] #1023946 07/18/11 01:05 AM
TOASTY Offline OP
I made the side templates, What do you think? I mounted the bumper to my truck without fender flares today, It'll look more correct on a truck with fender flares.
I think we may need to tow Lloyds truck to my house soon, a lot of the work left is on this side of town now. POOP
Re: Wrench fest for Lloyd [Re: TOASTY] #1023947 07/18/11 04:32 AM
That should work <img src="/forums/images/graemlins/kewl.gif" alt="" />
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.023s Queries: 14 (0.019s) Memory: 0.6572 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-11-03 20:14:42 UTC
